#1 |
Level concrete area ?
Since you have poured concrete before, perhaps you can help me! I have a concrete area that slopes and the slope is about 6 inches. On top of the slope is a flat concrete area where I used to have shed. I want to level the whole concrete area as easy as poss, of course. I then want to stain the concrete. The area is not huge - maybe 300 square feet and it is outside. Any ideas?
#2 |
I am thinking your reply as an auto response that did not generate from a live person actually looking at my post! Bear with me - I am female and worse yet, blonde. So, will someone actually post a helpful response and should I stay on line or can I go and make a cup of tea?
#3 |
Xtreme DIY'r
A 6" drop over what distance ?
1/4" per 4' is usually required for proper drainage If you want to level off a 6" drop you would need a new slab poured as far as I know |
#4 |
It was a dark and stormy
An unevolved chromosomal male, brown hair/eyes asks
300 sq. ft. as in 17' x 17'? 4" thick? Probably weighs 7 tons? http://www.google.com/search?client=...UTF-8&oe=UTF-8 Depending on the shape and how much force will be on the leveled plate you could cut grooves in the plate and then try to jack up or use 4x6s cut into long wedges and hammered in, to raise the plate. If it cracks along the grooves due to bending stress raise each lighter segment separately and pack the area between sections with a flexible filler. Last edited by Yoyizit; 08-03-2010 at 06:50 PM. |
| Display Modes | |
| How To Keep Your Concrete Mixer Driver Happy | Mort | How To Guides | 36 | 08-05-2012 11:43 AM |
| Crumbling Front Porch - Part 2 - The Repair | jerseyguy1996 | General Discussion | 9 | 04-11-2010 07:11 AM |
| Best way to attach low level deck to existing concrete slab. | fulghumd | Building & Construction | 4 | 03-11-2010 07:45 PM |
| Help!: 4" concrete over 2' dirt over 7/8 wood planking! | agent99 | Flooring | 4 | 04-28-2009 09:21 AM |
| Tile on concrete slab, ground level - bamboo? | IvoryRing | Flooring | 2 | 06-28-2006 09:52 AM |
