Less toxic building options?
I am gonna build a small 6x6 to 8x8 playhouse for my daughter but want to avoid all the nasty toxin for her and the planet. So far here is what I am thinking but open to any and all suggestions or ideas. I was going to build it up on 4x4 cedar skids to avoid the pressure treated there. just found these lp building products at hd and lowes . wood siding with no urea formaldehyde. gonna get used metal roofing from the recyclers. Either reclaimed or certified 2x walls and roof.
Big questions remaining are the floor. best thing i have come up with using exterior ply without the formaldehyde. lp has a osb but having that as the only floor outside makes me a little nervous still. any ideas on that one?? solid board ??
same deal with roof sheathing??
also the floor frame.....i dont want to use PT on it. I mean I guess i can just go untreated since it will be off the ground but open to ideas for that too. Maybe just a good rot resistant wood.
Thanks and any input would be great.
oh yeah it will have an overhand but was planning on just open windows....no glass etc. so floor needs to be able to handle a little moisture.....or have toyed with idea of dirt floor with cedar under the frame??
