Length Of Time To Dry Crawlspace? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 07:56 PM   #1
Rewards Points: 28
Length of time to dry crawlspace?
Hi all,
For the last 10 years the main sewer line pipes under the house have been leaking water in to the crawlspace. It was muddy in the crawl space naturally. 8 months ago we installed new pipes. Now the soil is very damp unsteady of muddy. Does it usually take this long for the crawls space dirt to loose the moisture? House is located in dry southern California. I have no fans attached to the crawlspace vents yet. I am thinking about getting some. Thoughts?
withoutapaddle is offline   Reply With Quote
Old 08-25-2012, 08:19 PM   #2
Rewards Points: 14,000
There is no secret formula. It would depend on soil conditions, how much ventalation, if there's more moisture getting in because of no gutters, no french drain, no slope to the grade around the foundation, mulch piled up againt the foundation, water table, amount of rain fall, ECT.
Old 08-25-2012, 11:26 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
8 months and it is still damp under there?
You still have a problem somewhere.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 08-26-2012, 12:11 AM   #4
Pro
Yeah, that water didn't sit under there that long in southern cali, it's coming from somewhere ...
smalpierre is offline   Reply With Quote
Old 08-26-2012, 10:29 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
If he has the same soil I do....sounds about right......also depends on the air circulation....
I had a damp/wet crawl space this past winter....combination of rains and no roof.....
I took a fan, put it over the access hole and turned it on.....ran for a few days....much dryer. Turned if off....couple days later....damp again....so I ran it some more....
It's fine now.
We have that horrible adobe clay soil....holds water real well....
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 08:13 PM
Crawlspace update WillK Insulation 2 05-01-2012 09:18 AM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 04:13 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
insulate damp crawlspace? 2001FZ1 Insulation 3 04-02-2011 08:35 PM
