#1 |
Length of screws for door hinges
Are 1/2" long flat head countersunk screws adequate for installation of interior doors onto a door frame? What is the retention force of a 1/2" countersunk wood screw in a pine wood frame. This is a new home and the general contractor provided interior door kits using 1/2" long screws.
#2 |
1/2" ?
![]() I'd go a little longer than that. At least 1.5 to 2"...but really, you can use as long as you want. Worst thing that can happen is you actually get into something solid |
#3 |
Usually aroud here the screws that come with doors are only 3/4" as that is how thick the door material is. For a more solid door, shim solid behind the hinge area and use 1.5-3" screws that get you into the stud. Predrill!!!
#4 |
MarginallyQualified
Length of screws for door hinges |
#5 |
I usually to the two furthest back from the edge of the stud on the top hinge (our hinges have 4 screws) The bottom hinge rarely pulls out. Also 2 longer screws into the door, predrill.
#6 | |
It was a dark and stormy
Length of screws for door hingesQuote:
http://www.screw-products.com/specs.htm |
#7 |
As others said.. using one longer screw per hinge will add some strength. I used one 3" screw per hinge and you can notice a difference.
#8 |
In a little over my head
A pre-hung door will have hinge screws that engage, but don't stick through, the jamb. Ya gotta be able to slide it into the RO. After it's in, change a few out for screws long enough to bite into the studs. If the casing's already on, there's no telling if there're shims near the hinge, so don't pull too tight.
| Display Modes | |
| best exterior screws? | miamicuse | Building & Construction | 11 | 12-22-2011 02:51 PM |
| Refinishing / Repairing Deck: Screws vs. Nails? | superhandymom | Building & Construction | 1 | 05-10-2010 03:08 AM |
| Hardwood Length...preference? | JDeFuria | Flooring | 3 | 03-10-2009 06:38 PM |
| Screws vs Nails in Interior framing project | alexz | Building & Construction | 2 | 07-05-2006 06:58 AM |
| DECK decking nails vs screws ... | christian15213 | Building & Construction | 8 | 05-02-2005 08:51 PM |
