Old 11-04-2010, 06:56 PM   #1
Legal weight limit for my dump truck
I have a single axile class 8 dump truck. The empty truck weights 15.500lbs. When buying the license plate and hauling what is the maximun Weight in tons I can put onto the truck and be legal? Thanks David
dnh082461 is offline   Reply With Quote
Old 11-04-2010, 07:04 PM   #2
Master General ReEngineer
Bondo's Avatar
Only the licensing authority knows that answer... Each state/ country is different...
Wheelbase, 'n tire size also comes into play...
Old 11-04-2010, 07:22 PM   #3
I have had a 33000lb tag for one year. When you go in to DMV they have a chart, you can buy as much weight as you want, but that don't make my truck legal if it is overloaded per the capicity of the truck. If the distance from hub to hub is fiveteen feet, what would the number of tons of rock I could put into the truck?
Old 11-04-2010, 07:33 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
A Trucker's Atlas would have the answers for some of the questions under the weight section. As for the truck, manufacturer & model helps those trying to answer your questions. Big difference from a Mack to a GMC, to a Ford F350.
Old 11-04-2010, 07:45 PM   #5
Bondo's Avatar
Ayuh,... There's Alotta ways a trooper can write ya an Over-weight ticket,...
Single drive axle,... 20,000lbs...
Single steering axle,... probably 12,000lbs, but could be rated higher...
Then the bridge law,...
15' is pretty long for that,... You'll probably be able to scale the full registration rate...
We used to have a short wheelbase R-model Mack tractor that we put a 9' box on,...
It could scale 9 tons pay-load...
Another 1 had a 10' box, 'n wheelbase to match,... it could scale 9.5/ 10 tons...
Here in Ny state anyways...
Upstairs weight limit osnits Building & Construction 1 10-16-2010 07:16 AM
dump truck weight s baron General Discussion 4 06-16-2010 06:21 PM
Makeup Counter Weight Limit? greylockwood Carpentry 1 02-14-2010 08:31 PM
Is there a weight limit in a Garden Window? rwith General Discussion 5 05-15-2009 05:02 PM
Load Capacity of driveway - Will a dump truck crack it? Deavis Building & Construction 15 09-04-2007 10:02 PM
