Ledger Length - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2013, 11:22 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Ledger Length
I'm building a deck that is 16' wide attached to the house. Does the ledger need to longer 16' or can I use the hidden fastener joist hanger and go right to the edge of the ledger?
TIA
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 10-01-2013, 11:47 AM   #2
cortell's Avatar
Rewards Points: 504
The latter. Aesthetics count when building a deck :-)
cortell is offline   Reply With Quote
Old 10-01-2013, 01:24 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
If you are stuck with a ledger attachment instead of a free-standing deck, make sure it is connected with the appropriate fasteners that may be required (through bolts and not just lag screws or nails). Also, make sure the entire ledger and fasteners are well flashed to prevent the feared moisture and rot.
Dick
concretemasonry is online now   Reply With Quote
Old 10-01-2013, 02:10 PM   #4
cortell's Avatar
Rewards Points: 504
Lag screws are fine. They need to be at least 3", and they need to sink into at least 1.5" of the home's rim joist. If you have a double rim joist or you can sink the lag screws into the home's joist ends, you can improve the connection by using longer lag screws. Now, if you have a basement or crawl space, and the home's first floor framing is exposed, then likewise, a through bolt (a.k.a., carriage bolt) is encouraged, as it will provide the greatest pull-out resistance.
Nails or decking screws...absolutely not.
Of course, none of this applies if you're tying into a concrete slab.
Old 10-01-2013, 02:43 PM   #5
Many municipalities will not allow lag screws and want through bolting. That is the right of a locality to have that requirement based on history of problems. A locality can always over-rule a model code (IBC, etc.) as long as it more restrictive since the model codes are the minimum standard and not always the best way to do things. They leave the scraps for those that just want a "cook-book" solution and not a good recipe.
Dick
Old 10-01-2013, 02:45 PM   #6
I have gas!
Thanks guys,
I'm following awc.orgs prescriptive deck construction guide. It will be fastenmaster ledgerlocks and Strongtie lateral holddowns. There's no siding on that side of the house so there are no excuses for not flashing correctly. I've even put 36" IWS up the side. for the first layer against the sheathing.
The Following User Says Thank You to Clutchcargo For This Useful Post:
GBrackins (10-01-2013)
Old 10-01-2013, 03:39 PM   #7
cortell's Avatar
Rewards Points: 504
Fair enough. Which is why it's always wise to check with the local building inspector when in doubt. If the OP solely listened to me, he may have found out his jurisdiction requires a connection stronger than what default code prescribes. If he listened to you, he may have needlessly torn up a finished basement ceiling. Multiple opinions usually lead to the best advice.
Old 10-01-2013, 03:49 PM   #8
ClutchCargo,
When I built my patio in 2009 with a ledger board I contacted Ledger Lock and received a complete engineering report that I brought to my city building department to get an approval. The city engineer was impressed with the shear strength the Ledger Locks provided. I also used more fasteners than was required by code. This is MY house and I had more than enough.
NASCAR9 is offline   Reply With Quote
The Following User Says Thank You to NASCAR9 For This Useful Post:
hand drive (10-01-2013)
Old 10-01-2013, 10:13 PM   #9
Registered User
Rewards Points: 4,894
That was good planning. The LedgerLoc has 70% of the "withdrawal" resistance as a 1/2" lag screw..... hence the closer on-center spacing required for them. Follow the manufactures instructions that differ from deck code.. When using lags, if permitted as said, the 1/2" long tapered tip is required to extend past the house framing (single 2x), not counted for the screw length, Fig. 20; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Old 10-02-2013, 07:51 AM   #10
I have gas!
With code now requiring separate lateral ties for deck attachment, is pullout strength for lag screws really a concern?
Old 10-02-2013, 08:32 AM   #11
kwikfishron's Avatar
Rewards Points: 84
If your area follows the 09 IRC then figure 14 and 23a in the Prescriptive Guide both apply.
http://publicecodes.cyberregs.com/ic...002_par014.htm
kwikfishron is offline   Reply With Quote
Deck ledger board attachment higher than rim board Davenger Building & Construction 0 06-20-2013 11:30 PM
Yes, another ledger board thread... MisterSteve Building & Construction 9 10-19-2012 02:04 PM
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
