Old 07-09-2008, 10:11 PM   #1
ledger for large deck area
I have just started rebuilding my pool deck and installed the first of 7 2 x 8 x 10 ft ledgers along concrete wall. the next ledge to go up is along a section of the concrete that has a 130 degree angle off the end of the first ledge that was installed.
/ 2nd ledger
(first ledger
what is the best way to butt the 1st and 2nd ledger together?
do they need to be butted since they will not show once the decking is installed? Thanks for any thoughts.
mnulty is offline   Reply With Quote
Old 07-09-2008, 10:17 PM   #2
Moderator
Termite's Avatar
The ends of the ledgers don't have to be attached or butted to each other. It is purely aesthetics, provided that your ledgers are connected to the wall properly.
Old 07-09-2008, 10:21 PM   #3
that what I thought but I new at this and I just wanted another option before I went any further
Thanks again
Old 07-20-2008, 08:01 AM   #4
HomeAdditionPlus.com
Your ledger boards will be hidden underneath the deck. They are for structural purposes only, so don't worry about how clean your ledger seams are.
Last edited by AtlanticWBConst.; 07-20-2008 at 02:02 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed from Signature
mjdonovan is offline   Reply With Quote
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
Deck Ledger Connection Question frederic.katz Building & Construction 2 05-08-2008 02:13 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 01:41 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
