Old 05-01-2012, 06:34 PM   #1
DIY Homeowner
Ledger and hanger both required for cantilevered joists?
I just got some info from my county building dept that does not make sense. They say that if I have cantilevered floor joists on the deck I'm planning to build, the opposite ends of the joists have to have hangers AND a ledger strip. How does that work? I figured the ledger must be required at the top of the joist (notched of course) to guard against uplift if there is too much weight on the cantilever at the other end.
The guy responded (e-mail) that the ledger can be either at the top or bottom of the joist. How the ..................?
Can anyone explain this? Never seen such in all my days.
Thanks in advance.
BRO931 is offline   Reply With Quote
Old 05-01-2012, 06:38 PM   #2
Lets see, no picture, no drawing, it's anyones guess as to what your trying to do.
Old 05-01-2012, 07:09 PM   #3
try this link
http://www.deckmagazine.com/pdf/2008/0805/0805stru.pdf
summit a drawing to them with your proposal ask them to approve or recommend any thing they do not like
normally we use one size larger than floor joist for ledger cut back siding if wood 4 inches below door for snow. slide ledger drip cap behind siding then slide ledger board up fasten accordingly to house, hang joist hangers on ledger and then hurricane hangers on cantilever beam
fasteners and hanger links
http://www.fastenmaster.com/index.html
http://www.strongtie.com/deckcenter/...?source=topnav
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 05-01-2012, 07:24 PM   #4
i personally do not like to do cantilever deck joist due to the appearance of the deck where joist sit on cantilever beam.
to understand what i am saying go to the treated lumber and measure width "height" of about 20 2x? that you will be using for joist and you will see normally 3/8 difference then pick them up and feel weight difference. and you tell me how to keep joist tight to beam for structural load and keep top of all joist in plain so deck does not go up and down.then what happens 5 years later when joist dry and shrink and then it looks worse and not resting on beam and being held by nails of clip
my 2 cents but only worth 1/2 a cent
Old 05-02-2012, 05:52 PM   #5
DIY Homeowner
Hopefully the attached image will help. I'm going to send this to the county also.
Old 05-02-2012, 07:50 PM   #6
GBrackins's Avatar
BRO,
check out this site http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf it is the Prescriptive Residential Wood Deck Construction Guide based upon the 2009 International Residential Code (basis for most state residential building codes).
it gives the requirements for deck construction.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
jaydevries (05-02-2012)
Old 05-02-2012, 07:52 PM   #7
GBrackins's Avatar
some local building departments have a "hand-out" for their requirements for deck construction, check with them to see if they do.
Gary
Old 05-08-2012, 06:25 PM   #8
DIY Homeowner
Well, after sending the previous drawing to my county building inspector, it turns out that they want a ledger AND a hanger on the opposite end of any cantilevered joist. They don't care which is on top. You can install the hanger upside down and use a ledger at the bottom the old fashioned way if you want to. Seems odd to me. I'll definitely do as illustrated below.
Thanks for all the comments and advice. This project promises to be interesting!
Ledger and hanger both required for cantilevered joists?-cantilever-required.jpg
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General Discussion 12 09-05-2011 10:46 PM
Placing joist hanger on top of ledger instead of hangers. hnd83 Landscaping & Lawn Care 1 04-15-2011 09:32 AM
Joist hanger to sill and ledger? chrishallowell Building & Construction 1 06-14-2010 10:09 PM
Gap between ledger and joists in hanger equilibrium1736 Building & Construction 16 04-14-2010 04:26 PM
