Old 06-26-2007, 01:42 PM   #1
Ledger Flashing
Hello, any tips on building and installing a ledger board flashing? I have a bending brake and a roll of 2 foot wide aluminum. Do I put the flashing on before hanging joists or after?? I'm desperate for advice...thank you in advance. Bryan D
flyultralite is offline   Reply With Quote
Old 06-26-2007, 02:09 PM   #2
Ledger Flashing
use copper with treated lumber....
RYANINMICHIGAN is offline   Reply With Quote
Old 06-26-2007, 06:10 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Ledger Flashing
As mentioned, you want to use either: COPPER or Heavily galvanized Steel sheets for flashing.
Discussion: http://www.oldhouseweb.com/stories/Detailed/14587.shtml
I recommend using copper DECK flashing (not to be confused with heavier gauge - expensive - rolls of copper roof flashing)
Example: http://www.yorkmfg.com/yorkShield106pt.asp
You don't need a brake to bend this type of flashing, as it is very pliable. It also has a soft polypropylene backing.
In this article, instead of using roofing felt as described, I suggest using a moisture membrane (like Grace Ice & Water shield):
http://www.oldhouseweb.com/stories/Detailed/14072.shtml
More information on how to layer flashing with a moisture membrane, see this link:
http://www.bestdecksite.com/introLedgerPg1.htm
- Build Well -
Do architectural shingles really work with step flashing? Malcolm Roofing 7 05-02-2008 11:31 PM
What kind of flashing Malcolm Roofing 4 06-20-2007 02:59 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
