Ledger Direct To Sill Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 11:44 AM   #1
ledger direct to sill plate
Can I bolt a ledger board for a (deck) directly to the treated sill plate.?
Paul K. is offline   Reply With Quote
Old 07-09-2011, 12:52 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
I'd say no. But above the sill there should be a band or rim joist. Typically 2 rows of fasteners are staggered 12" -16" oc or so, through the ledger into the rim.
Why did you want to use the sill?
12penny is offline   Reply With Quote
Old 07-09-2011, 01:38 PM   #3
Framing Contractor
Originally Posted by 12penny View Post
I'd say no. But below the sill there should be a band or rim joist. Typically 2 rows of fasteners are staggered 12" -16" oc or so, through the ledger into the rim.
The treated sill plate is what the band/rim board and floor joists sit on.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-09-2011, 01:51 PM   #4
Civil Engineer
Rewards Points: 4,520
Figure 14 in the IRC 2006 "Prescriptive Residential Wood Deck Construction Guide" shows the typical connection of the ledger to the rim joist or band joist. The sill is typically below the rim joist, it would be unusual to have the sill above the joist as indicated by 12 penny. Not saying it never happens, just unusual framing. The ledger is typically connected to the band joist because the depth of the ledger normally exceeds the depth of the sill, so it would presumably be difficult or impossible to get two levels of lag screws or through bolts through the sill.
However, if the sill is deep enough (mine is 3-1/2 inches deep), it should in theory be possible to lag into the sill beam for one line of bolts or lag screws, though this is NOT shown in Figure 14 as an allowable method, so before you do it, check with your local code enforcement official.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
12penny (07-09-2011)
Old 07-09-2011, 03:56 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
Doh!!! Typing and watching the Tour de France at the same time. Thanks for correcting me.
Old 07-09-2011, 04:13 PM   #6
Rewards Points: 1,092
Mistakes are allowed; NOT watching The Tour is NOT an option.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Joist hanger to sill and ledger? chrishallowell Building & Construction 1 06-14-2010 10:09 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 01:19 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
