Old 06-30-2009, 12:18 PM   #1
Ledger and Deck Remodel
I am working on a deck remodel, and have recently removed the extisting deck. I've kept the ledger behind, but am concerned about the remnants left behind by the old joist hangars and nails. Should I:
a) avoid or go ahead and attach the new hangars over where the old one's were... is there a stability issue?
b) if I avoid placing the new hangars over the where the old ones were, do I need to fill in any nail holes left behind... should I be concerned about water entering those holes?
c) replace the ledger altogether (although I don't really want to do that) ?
d) other suggetions I'm not even thinking of?
Thanks!
Mr.S Teacher is offline   Reply With Quote
Old 06-30-2009, 01:44 PM   #2
Remodeler
adpanko's Avatar
Why are you replacing all the joists and everything? Are they in bad shape, or are you just redoing the layout of the deck? If you are tearing it all out because they are in bad shape, then presumably the ledge is in bad shape too and should be replaced. But otherwise, so long as the ledger is pressure treated, seems structurally fine and is properly lagged into the house, I don't see why you can't reuse it. But without see it and the plan for the new deck, no one can say with certainty.
adpanko is offline   Reply With Quote
Old 06-30-2009, 04:42 PM   #3
I have worked in Puyallup for years as I live in Tacoma.
The Building Inspectors there are very precise, but fair.
The condition of the: flashing; ledger board; and bolts (quantity, spacing, length, galvanized coating left, and use of washers) would be my main concern.
I would replace it all to bring it up to the minimum safety code, which is why you should get a building permit. Be safe, G
GBR in WA is offline   Reply With Quote
Old 06-30-2009, 05:35 PM   #4
Thank you, G; that's a great point about the safety code. Do you see any issues with replacing the ledger board, but keeping the exisiting carriage bolts in place? Again, thank you.
Old 06-30-2009, 07:35 PM   #5
As codes are updated, a lot of the requirements become more stringent for safety. The spacing may not meet today's minimum standards, which are a lot better than yesteryear's. It is fairly easy to replace bolts, if difficult- it has outlived it's life anyway. Run the project past the City B.D. for the current spacing, size, length, etc.
Peace of mind, knowing that the new deck is safe for your family and friends, has a lot going for it.
http://www.nadra.org/industry_news/april07_woodbits.pdf Be safe, G
Old 07-02-2009, 09:48 AM   #6
Thank you, G. That's just the information I needed. I'm sure I'll be posting additional questions as my project continues. Perhaps we'll run into each other again. Again, thank you.
Tags
deck, hangars, joist, ledger
More On This Topic
This is an old deck where the joist were bad and this tongue and groove pine was on the deck which I have not ever seen before. This was totally unacceptable. I took up all of the tongue and groove going across the deck (12X17). The joist were all bad... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
Ok this is a continuation of the one board I took out and the ends all bad. It has the nails here and I'm going to cut the board across back here. You don't want to cut the board where there's already a joint, you want to stagger your joints back and... Read More »
On behalf of Expert Village, I'm Eric Williams and I'm here to tell you about reading music. Okay so you may say, this isn't so bad. Well it gets worse and there are ledger lines that go above the staff and below the staff so not only do you have to... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. When you are inspecting underneath you want to make... Read More »
Deck ledger vs band board wvw Building & Construction 2 06-02-2009 04:18 PM
Do I have to remove stucco to attach deck ledger? brandon272 Carpentry 5 04-03-2009 10:57 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 01:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
