#1 |
Ledger board support - life threatening?
planning to build a pergola in my patio and came up with this idea. Please see attached photo. my plan is to have 2 6x6 posts on the front and on the back I would like to have a ledger board and the rafters would be connected to the ledger board by metal hangers.
My biggest concern is, how to attach the ledger board on the side of the house. I don't want this to collapse and kill my family. we get some good wind on the backyard so it needs to be very stable. one carpenter said he can attach this to the studs with 3" screws but I need professional advice on the best way to secure this. it won't be carrying a lot of weight but has to be very secure. Please see the picture for details. Thanks for any input. |
#2 |
Haverhill Trade 1965
Industry standard is usually to use lag bolts into each stud in the wall, also there should be solid headers to bolt into over the door and window. You could add two 2 x 6's between door and light, and to the left of the window to look like half posts to mirror the 6 x 6 posts.
#3 | |
Ledger board support - life threatening?Quote:
as for using screws, I'm not sure how thick the siding is but the 2x8 ledger board would be 1 1⁄2 in thick. so there would be very little to be screwed into the studs. my concern using lag bolts is, I don't know what else is on the inside of the siding. there's a room on the other side and this ledger board would be within the room height and I don't want to disrupt the interior wall. |
#4 |
Why are you attaching it to the house at all. Most are free standing.
| The Following User Says Thank You to joecaption For This Useful Post: | concretemasonry (08-22-2012) |
#5 |
Mod
I agree that most are free standing but looking at the picture I'd have no problems attaching to the house.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#6 |
I have a patio cover very similar to what you are describing. During my design process, I relied on this local city's patio cover guidance:
http://developmentservices.cityofoxn...vices/b810.pdf It might help you with your design. Every city has their own building department, so check with them first. Also, this design is for California and we don't have many hurricanes here--just earthquakes This plan recommends using 1/2" by 5.5" lag bolts to connect the ledger to the house. Just make sure that they go into the existing wall's framing. It would be bad if your lag bolts just went into the siding material. Last edited by loftezy; 08-22-2012 at 06:59 PM. |
| The Following User Says Thank You to loftezy For This Useful Post: | GBrackins (08-22-2012) |
#7 |
If you decide to attach the ledger to the house, check out 'Ledger Lok'.
http://www.fastenmaster.com/details/...-fastener.html I used them for my patio with great success. |
#8 |
If you attach a ledger you need to pull off the siding and attach it directly. Then redo the siding around the ledger. Most cities have this as code these days anyway and generally attaching directly to the house will require a permit. Freestanding does not. At least that is what I found to be common around me.
#9 | |
| Display Modes | |
| Ledger board with engineered trusses (w/ picture) | danreg99 | Building & Construction | 7 | 04-14-2011 06:24 PM |
| replacing rotted sill plate and rim joist behind a deck ledger board | tommyt | Building & Construction | 2 | 08-11-2008 08:38 PM |
| Cracked ledger board on front porch | King_Doodle | Building & Construction | 20 | 06-03-2008 10:16 PM |
| Deck Building Question - Installing Ledger Board to Rim Joists | Ler0y Jenkins | General Discussion | 20 | 05-18-2008 12:05 PM |
| Installing deck ledger board over foam board? | RickT | Building & Construction | 5 | 11-06-2006 11:50 PM |
