-   -   Ledger board support - life threatening? (http://www.diychatroom.com/f19/ledger-board-support-life-threatening-154500/)
kimbhoot 08-22-2012 03:44 PM
2 Attachment(s)
planning to build a pergola in my patio and came up with this idea. Please see attached photo. my plan is to have 2 6x6 posts on the front and on the back I would like to have a ledger board and the rafters would be connected to the ledger board by metal hangers.
My biggest concern is, how to attach the ledger board on the side of the house. I don't want this to collapse and kill my family. we get some good wind on the backyard so it needs to be very stable. one carpenter said he can attach this to the studs with 3" screws but I need professional advice on the best way to secure this. it won't be carrying a lot of weight but has to be very secure.
Please see the picture for details. Thanks for any input.
Duckweather 08-22-2012 03:56 PM
Industry standard is usually to use lag bolts into each stud in the wall, also there should be solid headers to bolt into over the door and window. You could add two 2 x 6's between door and light, and to the left of the window to look like half posts to mirror the 6 x 6 posts.
kimbhoot 08-22-2012 04:56 PM
that's a great idea of putting two 2x6, however the main reason for not putting back posts is, on the right side where the light is, I can't put a post as the steps are on the way.
as for using screws, I'm not sure how thick the siding is but the 2x8 ledger board would be 1 1⁄2 in thick. so there would be very little to be screwed into the studs. my concern using lag bolts is, I don't know what else is on the inside of the siding. there's a room on the other side and this ledger board would be within the room height and I don't want to disrupt the interior wall.
joecaption 08-22-2012 06:09 PM
Why are you attaching it to the house at all. Most are free standing.
kwikfishron 08-22-2012 06:53 PM
199 Attachment(s)
I agree that most are free standing but looking at the picture I'd have no problems attaching to the house.
loftezy 08-22-2012 06:56 PM
I have a patio cover very similar to what you are describing. During my design process, I relied on this local city's patio cover guidance:
http://developmentservices.cityofoxn...vices/b810.pdf
It might help you with your design. Every city has their own building department, so check with them first. Also, this design is for California and we don't have many hurricanes here--just earthquakes :)
This plan recommends using 1/2" by 5.5" lag bolts to connect the ledger to the house. Just make sure that they go into the existing wall's framing. It would be bad if your lag bolts just went into the siding material.
NASCAR9 08-22-2012 06:59 PM
If you decide to attach the ledger to the house, check out 'Ledger Lok'.
http://www.fastenmaster.com/details/...-fastener.html
I used them for my patio with great success.
SeanB 08-22-2012 10:07 PM
If you attach a ledger you need to pull off the siding and attach it directly. Then redo the siding around the ledger. Most cities have this as code these days anyway and generally attaching directly to the house will require a permit. Freestanding does not. At least that is what I found to be common around me.
Duckweather 08-23-2012 09:43 PM
Hmmm I forgot about those. I have used them a couple times. They are sort of a lag/screw hybrid if I recall. Length would be about ledger + 2-1/2' = 4" without the siding, (looks like maybe 3/4" thick vertical). Cut tight to the bottom it would give minimal extra support. Also check town ordinances. some say when and if you need to apply for a permit.
Tham 08-23-2012 11:42 PM
I wouldn't worry at all at ledger locking a ledger in your situation. They have different lengths. The most important thing is properly flash after the roof is done.
Tham
