Ledger Board Rot - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 08:49 PM   #1
Ledger board rot
If the ledger board was not flashed and has visible rot in one area how likely is it that there will be damage to the house it self from the moisture?
shirleygirl is offline   Reply With Quote
Old 09-14-2010, 09:16 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
hard to say,maybe none maybe alot
Tom Struble is offline   Reply With Quote
Old 09-14-2010, 09:42 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Is it a ledger used for a "no-no" ledger attached deck?
If it is and it is not flashed and waterproofed around the attachment (through bolt preferred, but lag screws acceptable in some areas) to the rim joist, it certainly can be and you should look further for ANY signs of moisture in the wood or the fiberglass.
Dick
concretemasonry is online now   Reply With Quote
Old 09-15-2010, 08:25 AM   #4
steveel's Avatar
If you end up taking things apart, prior to reinstall you might want to look for a back issue of Fine Homebuilding, that featured an article on how to attach ledgers with not only flashing but draingage between the ledger and the house.
steveel is offline   Reply With Quote
Old 09-15-2010, 08:54 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
What Tom said. The important thing is to get it fixed this season. The longer you let it go, the more likely the damage will get worse.
And not an easy job with a deck in the way.
12penny is offline   Reply With Quote
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
Ledger Board Mounting Wildie Building & Construction 6 04-04-2009 11:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
