Ledger Board With Joist Hangars Flaw - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 06:13 PM   #1
ledger board with joist hangars flaw
my contractor wants to nail a ledger board partway up 13' 2x6 studs and use joist hangars to create a 2nd story floor area. the span is 21'. Seems like the 2nd story should depend on more than nails to hold it up or maybe the joists should rest on top of the 1st story walls. Is this a bad design or acceptable building practice?
treedisaster is offline   Reply With Quote
Old 10-14-2012, 06:33 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
its called balloon framing it was the method used before the modern method known as western platform framing
its still used today for stair landings but thats pretty much it. .
get him to throw in some bolts to make the connection a little stronger
woodworkbykirk is offline   Reply With Quote
Old 10-14-2012, 06:37 PM   #3
Rewards Points: 13,456
What's this for, outside deck, a loft area?
Is there anything over the 2 X 6's? Drywall siding?
What's the area going to have to support?
Lag bolts would be used to attach the ledger to the studs not just nails.
Old 10-14-2012, 06:55 PM   #4
Framing Contractor
What's this for? Do you have plans drawn from an architect?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-14-2012, 08:57 PM   #5
the other question is what is he planning on using for joist material.. tji's? its the only thing that can span that long. you might be able to get ojt's that will span that but ive never worked with ojt's longer than 15 ft
Old 10-14-2012, 09:12 PM   #6
robertcdf's Avatar
FYI, light gauge steel can span that distance.
robertcdf is offline   Reply With Quote
Old 10-14-2012, 09:22 PM   #7
Registered User
Rewards Points: 5,492
I remember another similar post about 3 years ago, can't find it now... The studs/ledger would require engineering as said, because of the fasteners weakening them there. The bearing roof loads above figure in to the calculations as does the house location; high wind, seismic, etc.; the foundation may need to be re-enforced due to added loads, etc., check with your local AHJ. A permit means "safe" minimum structural standards, and will help with your H.O. Insurance carrier if ever a claim and when you sell the house.
Gary
Old 10-14-2012, 09:22 PM   #8
Haverhill Trade 1965
The proper procedure was to cut the ledger (1-1/2") into the studs, and block between studs (2x6 ripped to 4" in your case) behind, or 2x6 above or below for firestop. It is illegal now in most of New England, maybe most other places, because of the fire hazard. You would have to check Life Safety Code in addition to building codes.
Duckweather is offline   Reply With Quote
The Following 2 Users Say Thank You to Duckweather For This Useful Post:
GBrackins (10-15-2012), mae-ling (10-14-2012)
Old 10-15-2012, 01:16 AM   #9
Here is the big picture
except 2nd story wall now 6' instead of 4'
joist material is manufactured, described as many 2x4 glued/fastened together, 12"
Old 10-15-2012, 10:19 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
So the structure is already built? Is it a structural ridge beam not requiring joists to hold the rafters together and that is why you are contemplating adding joists after the fact? If that is the case cut in the ledger to the 2x6 wall and use joist hangers for the joists. lag bolts might even be ok for the ledger but the ledger cut into the wall is best.
hand drive is offline   Reply With Quote
Old 10-15-2012, 04:12 PM   #11
GBrackins's Avatar
Rewards Points: 2,108
Duck hit it, don't forget your fire blocking or your stud bays will act as a chimney
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-15-2012, 04:40 PM   #12
Compliments of Haverhill Trade School, Haverhill Mass.
Old 10-16-2012, 09:59 PM   #13
Framing Contractor
Who's designing this? Do you have plans and permits?
Joe Carola
Old 10-17-2012, 04:35 AM   #14
Contractor disigned it, his primary business appears to be excavating. Permits are not required in this county and I have not seen plans yet, just descriptions. Once I have plans, I have no idea where to find someone to check them over, thus here I am.
ledger board tjlacy Tiling, ceramics, marble 6 03-05-2011 11:50 AM
ptw Rim joist = composite fascia board max_wonder00 Building & Construction 3 10-15-2010 07:05 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
