Ledger Board Flashing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 09:32 AM   #1
Rewards Points: 89
Ledger board flashing
Just put a ledger board on my house to attach decking to.
After removing the siding I added a piece of aluminum flashing between the ledger board and the house wrap.
One of my coworkers mentioned there was a problem with flashing deteriorating because of electrolysis between the flashing and the chemicals in the pressure treated wood.
Flashing is powder coated.
Is the flashing OK to leave up,or should I take her down???
spring3100 is offline   Reply With Quote
Old 06-09-2013, 09:42 AM   #2
Rewards Points: 13,712
Aluminum in any form should not be used.
You need something like copper, rubber, or vinyl,
Old 06-09-2013, 10:17 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
There should be, in an ideal application, some sort of separation between the two pieces.
The aluminum is not powder coated but does have an enamel paint on it. That being said, the galvanic corrosion will still happen (albeit at a much slower rate than if it were uncoated) where the water in contact with the two will mix and at the fastener locations.
We do use coated aluminum in some cases but only after putting some sort of isolation between the two.
The Following User Says Thank You to Windows on Wash For This Useful Post:
woodworkbykirk (06-09-2013)
Old 06-09-2013, 11:07 AM   #4
Roofmaster
Rewards Points: 2,210
The top flange goes under the house wrap. If the aluminum is painted, I think you will be fine. I use pressure sensitive EPDM though, as ACQ really attacks Aluminum.
The Following User Says Thank You to jagans For This Useful Post:
MTN REMODEL LLC (06-09-2013)
Old 06-09-2013, 11:17 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,208
pick yourself up a 4" roll of grace vycor or blueskin.. run a strip of it on the top edge of the ledger then install the aluminum flashing.. this is all thats needed to break the contact between the two materials.. basically what happens otherwise is that the aluminum will slowly turn to ash.. ive seen it a few times its not pretty
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (06-09-2013)
Old 06-09-2013, 02:08 PM   #6
Rewards Points: 89
Thanks for everyones input,I guess I'll be pulling that mother off tommorow a.m.
Better now than after I put the joists up!!!
Old 06-09-2013, 03:25 PM   #7
Old School
Willie T's Avatar
A good article on this....
http://www.deckmagazine.com/wood/bey...-flashing.aspx
Willie T
Old 06-09-2013, 03:45 PM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I used galvanized but I still put a layer of 30 lb felt between the two.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 06-09-2013, 04:31 PM   #9
What's it say in big letters right on the outside of the coil stock?
Do not put in direct contact with pressure treated lumber.
Old 06-11-2013, 07:29 AM   #10
Rewards Points: 89
Took the ledger board down,removed the flashing and installed flex-o-wrap instead.
As far as directions,maps and the sort,I only consider them a rough guideline and I usually discard assembly instructions immediately upon opening the package.
But thats just me.
Replacing Rim Board behind old Deck Ledger osubuckeye88 Building & Construction 11 10-26-2012 07:34 PM
Two piece ledger board for attached pergola, bad idea? TexasMan Building & Construction 3 04-28-2012 12:40 PM
Deck ledger vs band board wvw Building & Construction 2 06-02-2009 03:18 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
