Ledger Board With Engineered Trusses (w/ Picture) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 08:49 PM   #1
Ledger board with engineered trusses (w/ picture)
My contractor installed my ledger board for my deck (just nailed it to the house). Everything that I have read says to lag bolt into the rim joist. We have engineered floor trusses so we do not have a rim joist. I have found a picture online of what our floor trusses look like. Would it be alright to fasten using 2 lag bolts on each truss? ( or should I use carriage bolts like the picture?). WIll either of these methods support the deck? Thanks!
danreg99 is offline   Reply With Quote
Old 04-13-2011, 08:56 PM   #2
Civil Engineer
Rewards Points: 4,574
Pretty weak connection. You may want to consider installing a standalone deck.
Daniel Holzman is online now   Reply With Quote
Old 04-13-2011, 09:10 PM   #3
Framing Contractor
What do the plans say? The inspector will decide what is right or wrong.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-13-2011, 10:55 PM   #4
Joe, are you talking about the house plans?
Old 04-13-2011, 10:57 PM   #5
much better
I suggest you ask your contractor s that he will discuss to you what is the best for it. he must know it being the handyman doing such jobs. And what looks in the picture, it looks not strong hold.
_________________
jasonstrent070 is offline   Reply With Quote
Old 04-14-2011, 05:05 PM   #6
Well the contractor says that all they do is bolt 2 lag bolts into the floor joists. I will have to ask the inspector
Old 04-14-2011, 06:03 PM   #7
Registered User
Rewards Points: 5,244
Here’s your guidelines, from Fig.13b of this; http://www.lancova.com/deckinfo.pdf
http://www.sbcindustry.com/images/te...kLedger_10.pdf
Check with your local B.D. Be sure the exposed threads are equal to the nut thickness, not as pictured, to be safe.
Gary
Old 04-14-2011, 06:24 PM   #8
Carpenter
dtsman's Avatar
You are correct. A lag or carriage bolt will work. The deck has to bolt to the thick parts of the beam, not the OSB parts. Usually you lag it into the ends of the floor joist if not, to the top and bottom thick parts of the outter beam.
Nails are not considered structualy sound anywhere by any standard. Nailing would be ok if the ledger board for the deck sits on the slab or some other supporting structure.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Whirlpool refrig. problem ken1415 Appliances 147 02-25-2017 01:27 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Ridge Board vs Beam carrying load fauer Building & Construction 3 01-19-2008 10:39 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
