Old 06-10-2010, 11:58 AM   #1
I have gas!
Clutchcargo's Avatar
Ledger attachment for deck.
My house has balloon type framing at the sill plate. There is no rim joist and the studs go all the way to the sill plate. I want to attach the ledger to the sill plate and the studs as depicted. Before I fly this by the building inspector, is this idea acceptable?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-10-2010, 03:53 PM   #2
Mod
kwikfishron's Avatar
Do you have access to the wall cavities to drop some 4X blocks in there?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 06-10-2010, 04:11 PM   #3
concretemasonry's Avatar
Are you sure you want a ledger attachment instead of a "free-standing" or propped deck?
Some areas do not allow ledger attachment or do a very serious look at the possible leakage and moisture potebtial.
Dick
concretemasonry is offline   Reply With Quote
Old 06-10-2010, 09:04 PM   #4
I have gas!
I thought of a free standing deck but the idea of doubling the number of holes I need to dig (from 4 to 8) ... ugh... Just to give you an idea, I jumped on the shovel and it only scratched the earth.
Old 06-10-2010, 09:13 PM   #5
Mod
That’s what they make "Picks" for.
And I don’t mean a ice pick.
-NEW MEMBERS-
Old 06-10-2010, 09:48 PM   #6
It may depend on the jurisdiction!
Where I live, I was allowed to attach the ledger for the roof to the wall studs using 1/2" lag bolts.
In my case, the ledger was near the top of the stud, whereas yours is near the bottom.
Old 06-11-2010, 10:15 AM   #7
I have gas!
Dick
Alright if I need to dig more holes, so be it.
Free standing decks will need to be attached to the house using a ledger anyway. Am I wrong? This is from the Prescriptive Residential Wood Deck Construction Guide (Figure 23).
Old 06-11-2010, 10:18 AM   #8
Xtreme DIY'r
How far off the ground are you ?
On another thread someone said to put blocking across between the studs & bolt/lag to the blocking
Very tough, rocky soil here too
I lucked out digging my 1st hole, only a few rocks
Old 06-11-2010, 10:38 AM   #9
I have gas!
The deck will be about 40" off the ground.
It's not so much the rocks, although those are a challenge as well, the soil is rock hard as soon as you get through the top layer.
The post you are referring to, about the blocking, is above. To be honest, I don't know how that would be structurally different than lagging to the studs.
Old 06-11-2010, 10:49 AM   #10
Xtreme DIY'r
Taking apart inside walls would be a pain too
I'd run the ledger into the studs past the building Inspector before digging more holes
Might save you some work
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
