Ledge Plate Mounting On Uneven Concrete Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 04:38 PM   #1
Rewards Points: 105
Ledge Plate mounting on uneven concrete floor
Hello, I was looking for help on a header board that I'd like to mount to our concrete walkway floor instead of to our brick faced house.
I'm leaving the concrete walkway underneath, as the front deck will only be temporary. We have a small walkway that we'd like to add a ten foot wide deck onto. I've made a deck before, but here my problem is that I'm not using a ledge plate like I normally do.
I'd like to put one PT board along the side of the house, attached to the concrete floor and not the wall. Normally it wouldn't be difficult either but the concrete is (purposely) sloped for rail runoff.
Short of ripping a board diagonally to level it, is there a better way? I can only go past the concrete on one side, so I can't do posts and hover it over the cement, and attaching to the wall is not allowed.
Any ideas? Can I just shim the footer board with composite shims around where I'm securing it (every 18" OC).
I have attached a picture for review, any input greatly appreciated!
jdm001 is offline   Reply With Quote
Old 08-03-2011, 05:04 PM   #2
Rewards Points: 5,336
When you open the door, how much clearance do you have under it? Five or 6" at most?
What's the decking going to be, 5/4" or 2x4(2x6) material?
how far does the deck extend from the wall?
I see no space for a sill to rest the deck on. I do see a 2x6 cut on a bevel, resting on the overly slanted concrete, with a 5/4" decking material.
You can secure the joists to the concrete with "L" brackets.
Ron
B. Franklin 1759
Old 08-03-2011, 05:14 PM   #3
Rewards Points: 105
Ron, first off, thanks for the quick reply!
You're correct, I have about 5 inches of space for the door before I run out of room. I planned on making 4 posts on the grass (2 just off of the concrete for a stringer) and 2 about ten feet from the wall for the for front posts).
I planned on using 5/4 and using the stinger to help support the thin framing material. It's not going to have anything on the front porch deck, it's just to make a wider walkway.
Old 08-04-2011, 04:01 PM   #4
Rewards Points: 105
Ron,
What did you mean by using L brackets on the joists? Is that instead of joist hangers?
I didnt quite follow.
Sent from my iPhone using DIY Forum
Old 08-04-2011, 06:15 PM   #5
Originally Posted by jdm001 View Post
Ron,
You are resting the joists on the concrete by the door. You are not attaching the ledger to the house. The "L" brackets would be attached to the joists, resting on the concrete, which would be attached to the sloped walkway.
Ron
B. Franklin 1759
Can I install ceramic tile onto an uneven and un-level concrete floor? Integraoligist General DIY Discussions 17 02-03-2011 09:43 PM
Building a shower pan on a pre-sloped concrete floor tsg234 Kitchen & Bath Remodeling 1 02-06-2010 12:29 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 09:54 AM
Annie5 - framing over uneven concrete floor Annie5 Carpentry 9 11-22-2009 04:26 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
