Ledge, Filling Seams - Compound Or Wood Putty? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 06:28 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Ledge, filling seams - Compound or wood putty?
I have a ledge that I built around the family room. 10 inches wide. I used MDF for it and there are 4 seams where I had to join pieces together. ALso, I used a half round molding on the face. I would like to fill the seems between the pieces that joined together, and also a couple of areas where the molding has a tiny little gap. - As well as the nail holes from the finish nails I used to hold it down.
Question - I am thinking mix up some compound and use that for everything. SHould I do that or should I use wood putty. I will be priming the mdg w/ an oil base and painting glossy over it.
Thanks.
J187 is offline   Reply With Quote
Old 09-15-2007, 09:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use ""Ready Patch" putty compound. Dries quicker, dries harder, less shrinkage...but handles just like drywall compound. Sands easily too.
Links:
http://www.doityourself.com/invt/1408129
http://www.zinsser.com/pdf/TDB/readypatch.pdf
- Build Well -
Old 09-16-2007, 09:08 AM   #3
AWB would know better then I would but here is a little trick a friend who dose wood working showed me that has work real well for me.I mix up some of the sawdust from what ever I was cutting for trim (make sure it is clean) with varnish till it is paste like and fill in the gaps it takes a bit to dry but blends in perfectly so you cant even tell where one piece ends and the other starts
clasact is offline   Reply With Quote
Old 09-16-2007, 09:21 AM   #4
J187's Avatar
Rewards Points: 508
Thanks guys.
Old 09-17-2007, 08:53 AM   #5
J187's Avatar
Rewards Points: 508
That stuff worked great. Very nice to work with too. Goes on nice and smooth. Really good at seeking out cracks. No real shrinking and sanded quite easily. Thanks.
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Black wood putty JOHNL Carpentry 2 04-27-2007 11:35 AM
