Leaving A Garage With Exposed Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 07:10 AM   #1
Leaving a garage with exposed studs?
I'm renovating my single-car garage and have started to rip down the plasterwall boards...leaving the exposed wooden walls and studs. I'm really liking the look of the wood and am wondering about leaving the garage that way. Finishing it off with a nice clear/gloss stain. Searching around the Internet for photos of rooms with exposed studs and I haven't found any. Are there any reasons why I wouldn't want to leave it exposed?
Thanks!
dscamp is offline   Reply With Quote
Old 11-13-2011, 07:34 AM   #2
Rewards Points: 6,652
Attached or detached? You left that part out.
Old 11-13-2011, 07:36 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The natural wood will absorb light and cobwebs like to grow in the bays.......
but other than that......nope ....no reason.....done all the time.
NOTE:
The only issue may be firecode requirements between the garage and the house
Check with local code officials..........
tcleve4911 is offline   Reply With Quote
Old 11-13-2011, 08:51 AM   #4
Thanks for responding.
Its attached/adjacent to the house, however you cannot enter the house through the garage...there's no door to the home. The side of the garage that is adjacent to the home is insulated. I figured I would panel that side and leave the other walls and ceiling exposed.
Another issue...there are hundreds of nails jutting in from the outside asbestos siding. I was thinking of trimming all the nail-tips flat to the wood.
Old 11-13-2011, 09:56 AM   #5
Everywhere I have lived required an attatched garage to have 5/8 firecore drywall between the house and garage for a minimum 1 hour fire rating. That included the attic space if they were connected, or the garage ceiling if there was living space above.
Old 11-13-2011, 11:49 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
My original garage was just studs inside.....a real b!itch to keep clean. New garage is all drywall.....wouldn't do it any other way.
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
