Leaning Porch Column - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 11:36 AM   #16
Newbie Bill
Rewards Points: 520
I have no expertise but want to follow your progress and hope you can get this fixed. And as was mentioned, that is a very lovely looking home.
Please keep us updated.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 08-16-2012, 11:40 AM   #17
Love for Construction
<*(((><'s Avatar
First given you budget, I would contact the building department and see if you can get a consultation on fixing this, and what needs to be done regarding permitting.
Personally, depending on your skill set I would in your shoes be installing a temp brace for the roof, and then begin demoing and excavating. After the demo and excavation is done, I'm sure contractors will have a greater propensity of giving you a good bid and taking the job. As the house sits right now, without a contractor knowing what surprises are covered up their bids are going to cover their butts, and the prices will reflect so. If you get it uncovered and they can see what they are getting themselves into, as well as, not having to budget for the demo and excavation (which your are more than likely capable of doing) they will be willing to consider taking the job.
-luke-
<*(((>< is offline   Reply With Quote
Old 08-16-2012, 04:08 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Just a thought, if you contact a house mover they will usually have airbags that can lift that and maybe even move it, then the footing could be corrected and the column replaced.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-17-2012, 08:46 PM   #19
Update:
Just to keep the thread up to date. I had a mason come and look at the situation. He was basically uncomfortable from start with the prospect of the job.
He told me that my Mcyver solution would probably be doable given I have thick enough bars drilled into the footing,
He basically said that as a last resort he COULD demo it, get a sub contractor make a footing, and he would re-lay the brick. At a cost of about $4000.
I called 7 masons, he's the first to show up. 3 others told me they were coming today, but never showed.
zeffer111 is offline   Reply With Quote
Old 08-17-2012, 09:07 PM   #20
Rewards Points: 150
If you could get the weight off of it somehow, with that setup it would be hard to do. You could probably push it back straight....undermine it to the frost line and fill the hole with concrete. After a few days let the weight back on it.
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 09:11 PM   #21
What do you mean by "push it back straight"? any ideas on how I could do that?
Old 08-17-2012, 09:16 PM   #22
Rewards Points: 150
Once you get the weight off just push, or even a ratcheting tie strap from the other column next to it and crank it over
Old 08-17-2012, 09:24 PM   #23
Ok... I'm starting to get the idea.
Do you think I should use the far, larger size pillar, to wrap a large nylon racheting strap around and use to "pull" up the leaning one? or do you think the closer, shorter one would work?
I'd be a little afraid to use have the strap directly against the stones though. Maybe I could use a 4"x4"x4' with a rabit groove held against the outside corners of the columns... do you get my meaning?
Old 08-17-2012, 09:29 PM   #24
Rewards Points: 150
I'm not there but you get the idea, whatever works.
If my advise helped you hit "Thanks"
Old 08-17-2012, 09:30 PM   #25
Rewards Points: 150
Its not going to take alot of force to get it back to where it wants to be anyway...put cardboard under the straps.
Old 08-18-2012, 02:37 PM   #26
Rewards Points: 3,418
Not a good idea to put that kind of stress on that column,or you may have a bigger problem on your hands.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
kwikfishron (08-18-2012)
Old 08-18-2012, 03:43 PM   #27
Rewards Points: 190
We have two columns of similar stone block construction at the front of our driveway, about the same size as yours. One had a similar lean. The mason placed vertical boards at the corners and tightened ratchet tie downs to hold the column together. Then he drove wedges between the bottom of the column and the top of the footing until the column was plumb. It has stayed perfectly plumb for the last 20 years.
zircon is offline   Reply With Quote
Old 08-18-2012, 07:41 PM   #28
HHmm, very interesting idea. Sounds like it a very reasonable approach to this problem.
Where you around when the work was done? How did they drive the wedge in? What was it made of? Was it reinforced any in any other way like epoxy on the space around the wedge?
Old 08-18-2012, 07:51 PM   #29
Rewards Points: 150
Those driveway columns were not holding up a porch roof.
Old 08-18-2012, 08:07 PM   #30
I will be able to take all weight off the column before I do any work. I've also been looking closer at the wood section that sits on the top of the column. On the one that is leaning I can slide a string under it and feel that only one corner is actually holding any weight. The wood is around a 2"x10" thickness, I don't think the roof needs much support, the way it's built.
I think a wedge, with some type of hardener in the wedge crack, could maybe work.
What do you use in the crack if anything?
Front porch column help JRigby Remodeling 1 02-18-2012 03:09 PM
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 09:43 PM
Raising Fiberglass Porch Column xk49 General DIY Discussions 2 08-01-2011 11:11 AM
Stone or Block Porch Column Scoob66 Building & Construction 0 05-24-2010 12:48 AM
Removal of Porch Column sjsdesigns Building & Construction 4 04-12-2010 08:48 PM
