Leaning Patio Cover... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 02:55 PM   #1
kemerick's Avatar
Rewards Points: 85
leaning patio cover...
My co-worker has a leaning patio cover. All three posts are slightly rotted where they touch the cocrete and so all three are leaning about 2 inches out from the bottom in the same direction.
The cover is attached to the house via Simpson bucket type hangers across a beam. They allow for some play and of course being 20 years old, its all loose.
What would be the way to fix the lean? Would a cable across the top (catty corner to the other) with a turnbuckle take the lean out?
I am thinking he should replace the 2x6 boards that are sandwiching the 4x4 posts, as they are rotted and allowing for some lean.
Any other suggestions?
My constant project is my home, my play time is usually spent on my CNC router.
Last edited by kemerick; 07-14-2009 at 02:57 PM. Reason: I apparently can't spell today...
kemerick is offline   Reply With Quote
Old 07-14-2009, 04:00 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by kemerick View Post
..... Any other suggestions?
First, one at a time replace the posts
  1. Score a line in the concrete around all three posts
  2. Cut a temp post a little longer than the existing post
  3. Angle the top of the temp post close (4") to the top of the old post
  4. Sledge hammer the bottom of the Temp post until it is vertical
  5. Remove the original post.
  6. Bolt a Simpson AB Post Base to the concrete Pad (use ref score lines)
  7. Cut and install new post
http://www.strongtie.com/products/co...BA-ABE-ABU.asp
More later on replacing the 2x6's
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-14-2009, 04:37 PM   #3
Remodeling Contractor
Hi Kemerick,
Looks like PaliBob has this pretty well covered with the following additions:
* Your will need to "rack" the cover back into position. This can be done with the cable and turnbuckel as you mentioned or if the structure is small enough you can probably use a 2x4 steaked to the ground and propted on the top of the left most post (viewed from the yard). Don't push too hard - it will go the other way!
* After you follow PaliBob's steps, install diagonal braces post to beam. This should prevent the problem from reoccurring.
Good Luck
DaVinci is offline   Reply With Quote
Patio cover Jackhammer Building & Construction 3 07-10-2007 03:49 PM
Need help with patio cover supports alexfosse Building & Construction 2 05-02-2007 03:57 PM
