Leaning Garage Wall And Sagging Roof Line. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 09:18 PM   #16
Originally Posted by oh'mike View Post
Get us a picture of the complete truss----that truss looks like it's the wrong design----the bottom chord is not resting on the top of the wall----I wonder if they used trusses with extra long tails and used the tails as the supporting place for the truss instead of the bottom chord---
oh'mike,
four of the trusses have a bottom chord that rests on the top plate. 4 more have chords half way up the rafters. The rafters without any bottom chord are exactly as you describe, the tails are resting on the top plate.
jrb619 is offline   Reply With Quote
The Following User Says Thank You to jrb619 For This Useful Post:
oh'mike (10-20-2012)
Old 10-20-2012, 10:08 PM   #17
I'm not an expert in truss work--so take thhis one as a guess----
oh'mike & PLS,
Here are a few pix of where the rafters tie in at the top plate.
leaning garage wall and sagging roof line.-img_2155.jpg   leaning garage wall and sagging roof line.-img_2159.jpg   leaning garage wall and sagging roof line.-img_2160.jpg   leaning garage wall and sagging roof line.-whole-rafter.jpg
Old 10-20-2012, 10:27 PM   #18
Home Remodeler
Rewards Points: 164
Looks like the joists are 2x6 spanned about 24 feet. The span is to long and needs at least supported by a support wall or beam in the middle.
mikey48 is offline   Reply With Quote
Old 10-20-2012, 11:14 PM   #19
Rewards Points: 150
Originally Posted by jrb619 View Post
oh'mike & PLS,
Whoa!
I don't know how I missed the fact the span is about 24ft! Even if they weren't 2x6's and they were 2x12's, 24ft will still be over-extension...
Anyway, What you could probably do to rescue the weak roof is by adding a 2x4 under the 2x6 ties. This will create a upside down T if you look from a "cut" view. Use screws about 16" apart. Additionally, you could also fill in between where there is no 2x6's with more 2x6's (at least) and 2x4's (to form upside down T). By doing this, you should off-load the roof weight onto the newly added 2x6's w/ 2x4's. You will have to jack up the sagging 2x6's first though to get it as straight as possible. This way, the 2x4's will be installed to a straight 2x6 rather.
Again, you will still have to take care of the moving walls and corners I have mentioned already... These are the legs to the "weak roof"... Yikes... You can't fix your roof, until you have straighten out your walls and corners...
After you have straighten out your walls and corners, go ahead and add these (http://www.homedepot.com/h_d1/N-25ec...storeId=10051) to the 2x6's at the top plates... to secure their position going forward and eliminate "slide out"...
oodssoo is offline   Reply With Quote
The Following User Says Thank You to oodssoo For This Useful Post:
jrb619 (10-20-2012)
Old 10-20-2012, 11:22 PM   #20
Registered User
Rewards Points: 4,894
Get that door off the rafter ties, first, and any other load. The 2x4 and 1x4 "struts" or web members are helping the rafter ties, do not remove them. The 2x6 ridge board is fine, as are the collar ties, though they are only for high wind uplift to hold the rafters to the ridge board. This is not a truss system. http://publicecodes.cyberregs.com/ic...002_par018.htm
Check the amount of nails in each rafter ties (compare to the span/snow load listed, especially the one pictured inboard of the garage door opener; 9th chart down; http://publicecodes.cyberregs.com/ic...?bu2=undefined
The raised rafter tie takes the next chart adjustment factor below that. See where we are first, before fixing it.
Gary
Old 10-21-2012, 12:29 AM   #21
plan of attack
Based on everyone's great comments and feedback, i'm starting to generate a plan illustrated below. Let me know what you guys think. Is this sound?
1) create anchor plate on top of leaning wall with 2X6
2) drill eye bolts to anchor plate and into cement floor and attach turnbuckle.
3) build wall or use floor jacks and a beam under sagging joists.
4) tighten turnbuckle and raise joists simultaneously until leaning wall is vertical and joists are flatter
5) add new beams across span to stop wall from leaning out again. Q: what should the dimensions of this beam be? 2X6?
6) add collar ties and/or sister-up rafters as needed. Not quite sure how many ties will be needed and where. I assume lower is better?
7) remove turnbuckle and floor jacks/wall.
8) put my cars in here????
leaning garage wall and sagging roof line.-plan-1.jpg   leaning garage wall and sagging roof line.-plan-2.jpg
Old 10-21-2012, 07:34 AM   #22
kwikfishron's Avatar
Rewards Points: 82
I think youíre jumping the gun here. Pushing things around and throwing a few more nails in this isnít going to ďsolveĒ anything.
In short what Iím seeing is a failed attempt at a home made truss design. Being in Wisconsin Iím sure snow load weighs heavily into this too.
I think your first step should be to hire a design professional to come onsite and evaluate your situation and hopefully come up with a plan so you can work with what you have there.
Once you have that then you can figure out how youíre going to implement it. It will be money well spent.
kwikfishron is offline   Reply With Quote
Old 10-21-2012, 08:34 AM   #23
Rewards Points: 150
The problem is what everyone is saying, but the reason that one spot is worse is because you have that massive overhang at the end with no real tie in. That end wall has a ton of weight .
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 10-21-2012, 08:51 AM   #24
Rewards Points: 150
5) add new beams across span to stop wall from leaning out again. Q: what should the dimensions of this beam be? 2X6? You could reference the span chart and get an understanding in order to determine which is the best to use for your situation. Secondly, consider to add strength by screwing 2x4s to form an upside down T.
JRB,
Building a partition wall that is weight bearing is a good idea for this building. This wall does not have to be in the center, nor do you only need just one partition wall. The idea is to ease off the span from a 24' span to much less. Perhaps figure out what you want for the use in this building, then provide in your sketch your plan.
Secondly, lets say from a engineering angle of approach, once a wall or walls have been set, then the weight of the roof can therefore be transferred to the concrete floor. From this point, you can use the new wall or walls to push from upward the sagging roof - by way of forcing the ridge beam upward throughout its entirity. Further, then, you could adjust your walls with a security blanket in place knowing your roof won't fall down entirly.
Thirdly, do not forget to secure the walls from the outside for safety. Remember, these walls are important to secure as they are the lifeline to the entire building.
Forthly, I think the a ratchet system is briliant on your part. However, this could be risky if not done right and safely. (For an example, under stress, the negative force from the pull could cause only one or two of the wall studs to move and not the entire run like what you drew in your sketch) Difficult to orchestrate that via the blog here, but perhaps you could bring your idea to us by a sketch also, and let us "approve" them...
At any rate, no matter your approach, you will need a professional onsite to do this. For the simple fact that you will need laborer and muscles to lift, move, drag, raise, align, guide, and watch from the beginning to end. It is my observation that you are an intelligent individual, but sometimes, we could miss the most simple yet devestating things - akelius heel.
Ps. I enjoy your sketches, by the way! Keep them coming.
Old 10-21-2012, 09:00 AM   #25
DIY staff
Rewards Points: 7,174
This is a small garage----it might be time to remove the old roof----brace up the walls--and head to Menards for nice new trusses----and not waste time and money trying to jury rig the old sagging roof----
Hammer450R (10-21-2012)
Old 10-21-2012, 09:44 AM   #26
AHH, SPANS!!!
Rewards Points: 1,166
if you have a string line along the ridge and raise (jack)the ridge up to the string line and then add full length joists that go across the room and sit fully upon the top wall plates and connect to the lowest point of all the rafters where they rest on the top plate with adequate nailing and hurricane ties, you should be able to take the jack down and the ridge will stay where it is,straight. The pulley wire system will work in conjunction with/while raising the ridge. Personally, I would focus more on raising the ridge while watching the rafter to wall connection as the ridge goes up, it all could pull in by itself with no help needed or not.
hand drive is offline   Reply With Quote
Old 10-22-2012, 05:55 AM   #27
Originally Posted by pls8xx View Post
Look at how the bottom chord of the truss is connected to the lower end of the rafter. A failure of the connection at that point would produce outward bowed walls and the center of the bottom chord would carry the center weight of the roof, bowing down.
Where the hell are the nails?
Go back and read GBR's post (Gary). Read it twice. Then go to the excellent links he gave. Find the appropriate data for your roof.
Pay especial attention to the nail chart near the bottom of the second link. Since you only have a ceiling joist for every other rafter, those joists carry twice the load and there is twice the force to seperate them from the rafter at the heel joint.
Then make an inspection of your framing. When you understand what is failing you will be pointed at the right fix.
pls8xx is offline   Reply With Quote
Old 10-22-2012, 07:29 AM   #28
Rewards Points: 150
Just thinking outside the box here from what's already been said...but why couldn't you use double 2x12 LVL's with posts under and/or them and sister them to the existing 2x6's? You can park a truck on LVL's. They should be able to support your structure no problem.
Squished is offline   Reply With Quote
Garage: Increase Wall Height c5er Building & Construction 3 03-16-2011 01:27 PM
Sagging Roof nayak143 Roofing/Siding 15 06-12-2009 02:03 PM
fix a sagging roof ridge...?? red86yota Building & Construction 2 02-06-2009 09:46 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 05:16 PM
