Leaning Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 05:24 PM   #1
leaning garage
My garage is leaning to the right. how do i get it upright?
eugierom is offline   Reply With Quote
Old 05-13-2012, 05:29 PM   #2
Framing Contractor
Rewards Points: 118
It should be "left" alone.
Seriously though, we need some pictures to help determine the cause and provide a solution.
sixeightten is offline   Reply With Quote
Old 05-13-2012, 05:29 PM   #3
Rewards Points: 636
can you post pics inside and out hopefully not finished and size
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-13-2012, 07:20 PM   #4
Civil Engineer
Rewards Points: 4,690
Seriously, this is like posting that your stomach hurts on a medical forum and expecting a realistic answer as to why. Garages lean for many reasons, the solution to any problem begins with a thorough, careful, well documented analysis of the existing condition, an evaluation of possible reasons, and a reasoned conclusion. You need a lot of photos, and probably some careful measurements, before you ask how to fix a problem that is as yet undefined.
Old 05-13-2012, 07:34 PM   #5
Rewards Points: 528
Leans to the right, push on the left.....
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
gregzoll (05-13-2012)
Old 05-13-2012, 07:43 PM   #6
Framing Contractor
This is not a mind reading forum.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Greg24k (05-14-2012)
Old 05-13-2012, 08:31 PM   #7
Rewards Points: 6,652
Tell the Football team to quit using that wall as a tackling dummy. Or just start leaning to the other direction, so that it appears to be straight.
Old 05-14-2012, 07:39 AM   #8
Rewards Points: 282
you guys are too tough on the guy...
OP, just have superman spin the earth backwards for a while.... that should do it
jcrack_corn is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
SIDING- make leaning garage appear straight wwsteel Building & Construction 8 11-20-2010 07:21 PM
Leaning Garage jocaan Building & Construction 4 05-13-2006 09:32 PM
