Lean To Roof Rafter Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 05:58 PM   #16
Retired from the grind
Rewards Points: 6,652
See around post #2496 on his thread, for that link I posted, around page 167, regarding Shumaker Scott's current status on his German house rebuild.
Old 10-24-2013, 05:59 PM   #17
cortell's Avatar
Rewards Points: 504
Originally Posted by thrw View Post
No but I thought there was height requirements for openings like that.
If you're talking about a shed, I don't think there is, but I could be wrong. Ask your building department if that's an actual constraint before racking your brain trying to figure out a way around it. I'm not sure how you would flush mount a rafter end to a beam in a way that is structurally sound (i.e., would pass code, whether you'll need to or not). I've not seen any Simpson hanger for that application, but then again I don't know their entire product line.
cortell is offline   Reply With Quote
Insulating kneewalls vs roof in 1929 house BadHouse Insulation 6 01-27-2013 02:58 PM
rafter size for grass roof plschwartz Building & Construction 9 01-26-2013 06:29 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
