Lean-to Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 04:56 PM   #1
Lean-to roof
How far can you span a 2x6 for a metal roof for a carport. One side will be attached to an existing garage wall and the other will be setting on double 2x6's on top of 4x4 posts?
Neil Gregory is offline   Reply With Quote
Old 07-04-2012, 05:12 PM   #2
Rewards Points: 502
It depends on how far apart you fix the 2x6s. Obviously if they are miles apart, each will be carrying a heavy load and will not be capable of spanning far. If they are close together, they will each carry a lighter load and so could span further.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
mae-ling (07-04-2012)
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
