Leaky Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 08:33 AM   #1
Leaky basement wall
Hi all, leaky cellar wall problem
I am having a problem with my cellar wall it has leaked water for three days now along a crack and at the bottom of the wall ... How can I stop the leaking in so to fix the crack? we have had a lot of rain this year but it has not rained for two days now.. what to do?
charlie74 is offline   Reply With Quote
Old 10-05-2009, 01:17 PM   #2
concretemasonry's Avatar
Rewards Points: 2,650
Do you mean a crack in the concrete wall or at the joint between the concrete wall and a floor slab?
Dick
concretemasonry is offline   Reply With Quote
Old 10-05-2009, 04:42 PM   #3
Rewards Points: 4,796
as dick asked, a crk IN the wall OR the junction of the wall & floor ? ? ? another question would be this - conc OR block wall ? ? ? its rare any bldr installs waterstop in the ' cover ' if that's where the leak's emanating,,, it may've stopp'd raining but there's still wtr outside your wall that hasn't been absorb'd by the soil OR drain'd away from a possible toe drain.
Old 04-04-2016, 09:48 AM   #4
Rewards Points: 12
Re: Leaky basement wall
I dont know if your asking me if its concrete but my wall is very old its stone and its brittle and i know if i dont get out there and start putting concrete
between the stones my house is going to collapse
Buddylink is offline   Reply With Quote
Old 04-04-2016, 09:49 AM   #5
Rewards Points: 12
thats not the best of it besides my basement foundation sinking and leaking the main floor wall is bowed in about a foot
Old 04-04-2016, 09:51 AM   #6
Rewards Points: 12
so i was thinking should i dig around the outside of the foundation and repoint the stone then pull the wall out and do i ancor it somehow
Old 04-04-2016, 01:10 PM   #7
jlhaslip's Avatar
Rewards Points: 2,882
Re grade the lawn outside so it slopes away from the foundation will/should help.
Is there a drainage pipe along the wall down near the footing? It might connect to the sewer or drain to open air someplace. Maybe that is plugged.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-04-2016, 03:58 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... This is confusin',.... Charlie ain't been here since '09,.....
Nobody's asked you anything yet,.....
But this is for You,...
Does the grade outside the house pitch Away from the house,..??
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
Basement knee wall question vugger Building & Construction 2 01-05-2008 09:02 PM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 08:35 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
