Leaking Window Rotton Plywood And Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 06:39 PM   #1
Leaking Window rotton plywood and studs
Sugar ants found in wall beneath window seal. Plywood rotted thru, studs not so bad. Is this because of a leaky window seal allowing moisture into the wall and creating a habitat for the ants? I am prepairing to remove the vinyl and replace the plywood, studs, and drywall so I can finish the room. How can I assure this problem doesnt repeat itself in the future?
Photo attached...
Thanks in advance for your advice!
jimreed02 is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 09:14 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
