Leaking Wall, Even With Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2007, 11:44 AM   #1
Post
Leaking Wall, even with Siding
Hello,
I bought a house with an installed siding on the backside. Everytime when it rains, the inner wall gets all wet. It is especially visible now when all sheetrock has been removed during renovation. Part of the problem, I think, has to do with the gutter, but what really surprises me is that the wet spots are on the first and ground floors (the second floor wall is dry).
Does anyone have any suggestions on how to seal the siding in order to fix this problem? The siding was put directly on the naked brick. Should I be putting some insulating material on the brick underneath the siding?
Thanks,
Art2670
art2670 is offline   Reply With Quote
Old 07-24-2007, 11:58 AM   #2
Rewards Points: 5,336
You need to figure out why the water is getting in. The brick should be keeping the water out. Why somone would put siding over brick is another question. Siding can get water behind it due to poor flashing details around windows and doors. It can also let water in if it is inundated by a gutter overflowing above it.
You need to correct the flashing details that's allowing the water in. Insulation at this time will just trap the water against the surfaces. Clean the gutters and cover them to reduce periodic cleaning.
Did anyone tell you why the brick was covered with siding?
Ron
Old 07-24-2007, 01:43 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
I would bet on poor flashing around the windows. - This is one of the safest bets to make since such a high percentage of window installation and window flashing is bad.
the wall may have leak before the siding was put on and that could be a feeble attempt to correct a very basic problem around the windows.
Siding should not be sealed!!!!
concretemasonry is online now   Reply With Quote
Old 07-24-2007, 03:28 PM   #4
I have no idea why the brick was covered with siding. This is an attached house which is 70 years old. I guess it was a quick and cheap attempt to prevent the wall from leaking, as I see that five other houses on the same block have the same siding.
Thanks,
Old 07-24-2007, 07:53 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Seen this before: Check your roof too.
- Build Well -
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Roof leaking where it intersects wall.. mellody28 Roofing/Siding 6 11-06-2005 10:26 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
