Leaking Superior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 03:31 PM   #1
Rewards Points: 150
Hi all,
I have superior walls in my basement and I noticed a pretty substantial leak today. There are (4) plates around our egress door that I assume bolt the preformed concrete egress staircase to the superior walls. Below is a picture of what I am seeing. Only one of the plates is leaking right now but if one is leaking how far behind are the other 3??
Any suggestions on how to fix this leak? Can I use a impact wrench to snug up the bolt and tighten the plate?....is there potential to crack the superior wall doing this? Can I remove the plate, recaulk and tighten back up?
Help!!
Jason
stradt03 is offline   Reply With Quote
Old 09-27-2011, 04:13 PM   #2
Rewards Points: 5,336
There are no pictures.
Ron
B. Franklin 1759
Old 09-27-2011, 04:47 PM   #3
Rewards Points: 150
Pictures are showing up for me.
Old 09-27-2011, 04:50 PM   #4
kwikfishron's Avatar
Rewards Points: 194
You're not going to be able to fix that from the inside.
kwikfishron is online now   Reply With Quote
Old 09-27-2011, 04:56 PM   #5
Wasn't there a gasketing material placed between the staircase and the concrete wall when it was installed?
Ron
B. Franklin 1759
Old 09-27-2011, 07:05 PM   #6
Rewards Points: 150
I have no idea. It was a spec home, built before I purchased it. If I had it built, I would have been on-site daily overlooking the progress. Unfortunately this seems to be an circumstance of shotty workmanship.
Old 09-27-2011, 08:11 PM   #7
Rewards Points: 150
Well I took my chances and took the bolted plate out, just as suggested earlier there is no gasket material between the plate and the wall.
I looked inside the crevice and noticed a bunch of crap and dirt. Obviously there has been water building up back there for some time.
Here is the back of the plate
Is there any kind of expanding sealant I can fill the crevice with then use a good sealant like Lexel on the back side of the plate and bolt it back up? What is the best course of action?
Old 09-27-2011, 08:29 PM   #8
"...just as suggested earlier there is no gasket material between the plate and the wall."
That was not what was suggested.
There should have been a gasket on the outside wall between the staircase and the wall.
Ron
B. Franklin 1759
Old 09-28-2011, 07:21 AM   #9
Rewards Points: 4,534
1 should not seal leaking bsmts from the inside as wtr still penetrates the found wall & attacks the concrete's cement's lime leading to found wall damage. you MAY be able to inject hydrophyllic polyurethane grout/foam thru the wall to seal the penetration however the tried & true method is exterior excavation,,, 5min when building the found now = approx 2day's work however those guys got paid & they're gone
Old 09-28-2011, 12:06 PM   #10
Rewards Points: 150
I would think I would want hydrophobic foam? Isn't hydrophilic "water loving"?
Old 09-28-2011, 12:45 PM   #11
AGWhitehouse's Avatar
Yes,
Hydrophobic repels water
Hydrophilic attracts water
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-28-2011, 03:22 PM   #12
house is correct in his definitions altho its clear he doesn't do this work for a living hydrophyllic is activated by wtr therefore sealing the penetration - we use it for sealing active leaking cracks in conc,,, note - you CANNOT buy this stuff in an apron/vest store - call your local const or concrete repair supply house - this may help:
http://www.waterworld.com/index/disp...iltration.html
Old 09-30-2011, 06:55 AM   #13
Rewards Points: 150
Verified that there is a gasket between the wall and staircase. I think the water may be infiltrating through the bolt hole as there is some slop in the tolerances. Maybe some silicone in the hole when I bolt the plate back together?
Old 09-30-2011, 07:38 AM   #14
Concrete & Masonry
Rewards Points: 530
How old is the house? I was always under the assumption that Superior Walls had a 20+ year warranty, may want to look into it and let them figure it out.
jomama45 is offline   Reply With Quote
Old 09-30-2011, 08:25 AM   #15
Rewards Points: 150
A little over a year. I don't think this is a superior wall issue though. All of the joints of the superior walls are dry. The leak is coming from the bolt that goes through the superior wall to hold the pre-fabed egress staircase fast.
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
