Leaking Gable Vent - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 08:21 AM   #1
Leaking gable vent
I have a gable vent on the south-westish side of my house and it takes the full brunt of just about every storm that comes through. usually it isn't bad but over the last year we have had some wicked weather with a lot of wind and it is blowing water through the slats which is then hitting the air duct below and telegraphing through the ceiling. Is there anything I can do to maintain the ventilation but help shore up the water infiltration?
cellophane is offline   Reply With Quote
Old 07-06-2012, 01:21 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
is it an old wood or metal?the right way is to install a pan to catch any water that gets thru the vent and direct it to the outside
to do this you would need to remove it and then reinstall it
the newer vinyl gable vents are less prone to leak but it can still happen
do you need the gable vent anymore?if you had a new roof installed you may have a ridge vent in which case you can eliminate the gable vent...according to most
Tom Struble is offline   Reply With Quote
Old 07-06-2012, 03:07 PM   #3
I have a ridge vent but the attic still gets stupidly hot (100+ temps don't help.) The gable is fairly large so having the detail on it helps break it up. I'll look into a pan and reflashing it however. I believe the vent is wood but I'm not 100% certain - it's been a while since I've been up there and I can't get to it from the exterior due to lack of a tall ladder.
If I don't need it I could add a pan and a vapor barrier that drains into the pan to prevent any wind driven rain couldn't I? The storms that have caused the most issues that I've seen have had 50+ mph winds =/ A normal rain doesn't seem to affect it.
Old 07-06-2012, 03:58 PM   #4
Rewards Points: 150
Your gable vents maybe impacting the effectiveness of your attic ventilation. If the ridge vent is able to draw enough air through the gable vents, then it won't draw through the soffits.
If you are concerned about looks, you can get dummy gable vents or seal the existing vents from the inside.
goosebarry is offline   Reply With Quote
Old 07-18-2012, 08:35 AM   #5
Thanks. I didn't think about that. Once it's not an oven in the attic I'll go up and take a look at everything.
Attic: Ridge vent and only 1 gable vent - no soffits - adequate for circulation? Chris Sweeney Building & Construction 17 07-11-2012 03:12 PM
Gable vent with roof vent. pjm30043 Roofing/Siding 9 06-20-2012 03:41 PM
roof leaking 5 ft. below exhaust vent mayhem69 Roofing/Siding 65 10-28-2011 03:48 PM
86 the Gable Vent??? 11thHourZero Roofing/Siding 5 07-17-2011 07:09 PM
bathroom vent leaking listo HVAC 3 01-24-2009 06:15 PM
