Leaking Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2005, 08:31 AM   #1
leaking basement
My sidewalk abutts and slopes toward the house foundation. Evidence of patching cracks between foundation and walk are present. I estimate the negative slope to be around 3 inches on this 2 ft. sidewalk. I'm looking for a permanent DIY fix. I prefer not to remove and replace the existing walk. Is mud jacking a possible DIY project? Is adding concrete on top of the existing surface an option? Which of the two options is better in terms of cost and longevity? The length of the walk is approx. 35'. Thanks for the input.
jd
jdwdwd is offline   Reply With Quote
Old 01-19-2005, 10:37 PM   #2
Rewards Points: 150
Originally Posted by jdwdwd
My sidewalk abutts and slopes toward the house foundation. I estimate the negative slope to be around 3 inches on this 2 ft. sidewalk.
Are you saying that the side against the house is 3" lower than the side away from the house?
If I understand what you've described, the only permanent fix involves removing and replacing the sidewalk.
No
In the abscence of adressing what it is that's causing the sidewalk to reside, there is no good option. Where do you live?
jd
A 35 x 2 x 4" sidewalk only requires about $250 worth of concrete. If it was me I'd: 1.) remove the old sidewalk 2.) compact the ground against the house and correct any drainage problems 3.) pour a new sidewalk
pipeguy is offline   Reply With Quote
Old 01-21-2005, 10:41 AM   #3
Pipeguy,
Thanks for your input. Yes, the side next to the house is approx. 3 inches lower. The house is about 50 years old and is located in the city of St. louis, Mo. I believe this situation is a result of settling. It appears to have stopped.
OK, I'll remove the old sidewalk, backfill as needed and pour a new walk.
Should the backfill material be soil with high clay content or can I use stone or something else? Should I attach the new pour to the existing foundation with rebar or wire mesh or should I not attach it to the house? Does it make any difference if the foundation is concrete block or poured? Any other thoughts?
jd
Old 01-22-2005, 09:44 AM   #4
PRO
Glasshousebltr's Avatar
jdwdwd, I'm not to far from you. Give me some more input, maybe even a pic, and I'll shoot you a figure to drive over for the repair. Maybe two days work absolute tops.
Bob
Glasshousebltr is offline   Reply With Quote
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 10:21 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 08:42 AM
condensation leaking in basement! geniedee HVAC 3 08-25-2006 08:58 PM
Leaking basement.. MRHOCKEY2434 Building & Construction 1 12-29-2005 06:07 PM
