Leak Where Brick Wall Meets Vinyl Siding - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 01:17 PM   #16
Concrete & Masonry
Rewards Points: 610
Sounds like a "recipe for disaster", OSB w/o any WRB, brick on one side, vinyl siding on the other.......................
jomama45 is online now   Reply With Quote
Old 02-04-2013, 03:48 PM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The lack of a WRB is the most troubling part to me. I don't know how that OSB isn't completely swollen up if that is the case. Vinyl siding inherently design for some moisture behind it, so to suggest that any small amount that would get in past that caulked vertical j-channel would be a big deal is a bit overstated IMO. That is why proper window and door flashings (and WRB) are so critical on vinyl sided homes, because moisture is going to get back there one way or the other.
Are you sure that you have nothing but vinyl siding just installed over OSB? No house wrap or insulation board back there?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
woodworkbykirk (02-04-2013)
Old 02-09-2013, 12:00 PM   #18
The house has no weather wrap behind the siding. It was build in 2004 and all in my neighborhood were built this way. The newer ones have wrap. Here is an image of what is above the corner.
Last fall a wind storm blew off some shingles above and also the valley flashing on the roof. Had a lot of water come in the home. Fixed the roof, opened up the wall cavities, removed the insulation, let it try, put new insulation in. It's been sitting this way for a while through some windy storms and haven't had any water come in. Last weekend went to put drywall back on and noticed moisture/frozen water. Think this may be due to cold temps and wind blowing through that crack in the caulk.
What is surprising to me is that this is a very common scenario (brick front, siding side) but I cannot find any documentation describing how the corner should be flashed and transitioned from the brick to siding.
jason.shaffer is offline   Reply With Quote
Old 02-09-2013, 12:23 PM   #19
Rewards Points: 2,516
Keep an eye on those window sills you have. Those are called rowlocks.
I had a mystery leak. My culprits were the window sills which were a rowlock course of brick on each of the windows on the front brick veneer of my home.
I ended up having all seven rowlock sills replaced with solid limestone sills on front of house.
Look under those sills and see if you have any voids in either the head or bed joints for weep holes. The weep holes will allow any water that gets behind to veneer to "weep" out.
hammerlane is offline   Reply With Quote
Old 02-09-2013, 12:38 PM   #20
Yes, I have a leak under that front window, I believe since the house was built. When I opened up the side wall from the roof leak I also opened up the front wall underneath the window and the OSB is completely rotted out. Can practically push right through it. Not sure what to do there either in terms of finding where the leak is...
Old 02-09-2013, 01:44 PM   #21
Was really excited to see this underneath the bottom of the roof valley flashing...
Old 02-09-2013, 02:02 PM   #22
Haverhill Trade 1965
Looking at the second picture that looks like an outside corner cut to the brick, or the brick is on top of an outside corner. You might see the sheathing in the space between brick and wall. If you don't intend to do more than re caulk, then at least use a good elastomeric calking. Sticks to everything, stays elastic, re seals itself if cut, can be painted and re calked over itself, and most have a 50 year guarantee. Just make sure to get the one that has a flammable warning, not a latex.
Duckweather is offline   Reply With Quote
Old 02-09-2013, 03:08 PM   #23
Originally Posted by Duckweather View Post
Looking at the second picture that looks like an outside corner cut to the brick, or the brick is on top of an outside corner. .
What 2nd picture are you referring to?
Old 02-09-2013, 03:09 PM   #24
Originally Posted by jason.shaffer View Post
Yes, I have a leak under that front window, I believe since the house was built....
Is this the outside vs inside view??
Old 02-09-2013, 03:14 PM   #25
Yes. That is an outside/inside view of the front window.
I also have a different leak (or leaks) on the vinyl siding side of the house which is where to OP comes in (caulking up the side of the brick) and the horrible roofing job.
Old 02-09-2013, 03:23 PM   #26
No idea what that means.
Old 02-09-2013, 03:25 PM   #27
Check the window sills on that leaking window.
Here is a video of rowlocks leaking. From the camera view it may look like the water is running off the front face of the brick but I assure you it is not. All the water is being drawn into that mortar joint, running down behind the brick veneer and ending up leaking out the top of the bay window.
Old 02-14-2013, 09:26 AM   #28
Sorry, lost track of which picture. The closeup of the calked joint
Vinyl Siding Sloping Wall swiederin Building & Construction 1 10-11-2011 03:08 PM
Porch Roof meets side wall..siding question sissy60504 Building & Construction 3 05-17-2011 06:58 AM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 10:11 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
