Old 01-06-2011, 10:05 PM   #1
Question
leak leak leak
Please refer to the attached pictures.
The house is only 5 years old with walk-up basement. Basement wall is poured concrete. In raining day, two places leak pretty bad. All other place are fine. One leak is around a PVC pipe going into the house. There are a well water pipe and a power line going through the PCV pipe. The other is around the septic pipe going out the house. Both places are underground. For the leak around septic pipe, the outside of the house is a porch. No one recommend to tire down the porch to fix the leak from outside. From the pictures, you can see there are white crystallized stuff around the cement surface near the pipes. I don’t see the white stuff from other place of the concrete wall. The cement around the pipes is clearly different from the cement of the concrete wall.
My questions are:
!. What can I do with the leak around the septic pipe? I can do it only from inside of the basement. This is the most headache part!
2. should I chisel off all the cement from inside to outside? Is it necessary? what kind chisel should I use?
3. I am planning to fix the first leak around water pipe from inside and outside. should I use hydraulic cement to fill the hole and apply roof cement from outside? should l do anything with the PVC pipe?
4. A waterproofing contractor suggested building an in-house French trench. This will cost too much. Is it an over-kill? Or the best solution?
dongdong1 is offline   Reply With Quote
Old 01-06-2011, 10:14 PM   #2
Xtreme DIY'r
leak leak leak
Where are you located ?
Old 01-07-2011, 06:54 PM   #3
leak leak leak
Maryland
Old 01-11-2011, 10:15 PM   #4
leak leak leak
itsreallyconc,
could you help with my question? Thanks a lot!
Old 01-11-2011, 10:21 PM   #5
joed's Avatar
leak leak leak
Dig on the outside. Seal around the pipes. seal the wall. Install proper drainage tiles and stone drainage.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
dongdong1 (01-18-2011)
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
