Leak In Cement Block "foundation" Of Bulkhead... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 05:56 PM   #1
leak in cement block "foundation" of bulkhead...
I had a new bulkhead installed in2006. The underground foundation is made of solid cement blocks and mortar. On one side, just below ground level, the actual blocks are leaking water on one side. There is only a 5" space between the edge of the bulkheasd and the porch foundation--a person can't fit beside the bulkhead.. I can't see any big cracks--the blocks themselves just have water seeping through. Will this have to be ripped out to try to fix it?
Helene is offline   Reply With Quote
Old 05-29-2010, 06:01 PM   #2
Rewards Points: 4,534
you mean ' grout filled ' conc blocks,s right ? sure would help if you had a picture here where's the water coming from ? as you probably suspect, water penetrating blocks is NOT a good thing
another question - WHY a bulkhead ?
Cement Block Basement Walls Cactus Rose Remodeling 8 11-02-2009 12:51 PM
how to waterproof exterior cement block walls dimmi Painting 5 07-11-2009 05:39 PM
Patch cement block wall? k.kuenn Building & Construction 4 05-31-2009 08:40 AM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
