Old 02-07-2013, 02:53 PM   #1
leak between sun deck addition and house
I am in the process of redoing our sundeck and wanted to eliminate a water infiltration problem. Along the area where the addition meets the house is a gap/open seam that extends the full depth of the metal pan concrete deck.
My plan of action was to remove all the loose concrete and debris then apply an expanding spray foam. Then I was going to apply waterproof concrete over the entire surface and finish it off with a product called Siliconizer here in Costa Rica. Here is the link to the product http://www.lancopaints.com/english/p...f_coating.html
Am I going about this the right way or should I take a different route?
leak between sun deck addition and house-sdp.jpg   leak between sun deck addition and house-sdgap.jpg
fatboyelroy is offline   Reply With Quote
Old 02-07-2013, 05:57 PM   #2
Nope, spray foam is not water proof and anything hard used to cover it will just crack.
The wall does not move, that slab does.
Clean it out and fill the gap with foam backer rod, then use something like this to fill the gap.
http://www.dap.com/product_details.a...=26&SubcatID=6
fatboyelroy (02-07-2013)
Old 02-07-2013, 08:26 PM   #3
Thanks for the tip on filling the gap. Is my approach to finishing off the entire surface sound?
Old 02-07-2013, 08:29 PM   #4
No, what you suggested will just crack, what ever goes there needs to be flexable.
Old 02-07-2013, 09:13 PM   #5
Not the joint area but the entire sun deck surface. There used to be tile. I ripped it all up and want to apply a decorative water based concrete layer, about 3-4mm thick.
Old 02-07-2013, 09:43 PM   #6
There's at least 2 concrete guys on here from time to time I'll let them suggest something.
House addition over existing concrete porch slab Hardwood Head Building & Construction 10 10-23-2012 08:46 AM
Deck pulling from house bereacj Building & Construction 5 10-20-2011 11:51 AM
Room addition connection to existing house? vsheetz Building & Construction 7 04-21-2011 03:56 AM
Old brick addition on old brick house, pulling away? Salvatorparadise Building & Construction 7 11-23-2010 07:05 PM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 10:40 PM
