-   -   leak between sun deck addition and house (http://www.diychatroom.com/f19/leak-between-sun-deck-addition-house-171308/)
fatboyelroy 02-07-2013 01:53 PM
2 Attachment(s)
I am in the process of redoing our sundeck and wanted to eliminate a water infiltration problem. Along the area where the addition meets the house is a gap/open seam that extends the full depth of the metal pan concrete deck.
My plan of action was to remove all the loose concrete and debris then apply an expanding spray foam. Then I was going to apply waterproof concrete over the entire surface and finish it off with a product called Siliconizer here in Costa Rica. Here is the link to the product http://www.lancopaints.com/english/p...f_coating.html
Am I going about this the right way or should I take a different route?
joecaption 02-07-2013 04:57 PM
Nope, spray foam is not water proof and anything hard used to cover it will just crack.
The wall does not move, that slab does.
Clean it out and fill the gap with foam backer rod, then use something like this to fill the gap.
http://www.dap.com/product_details.a...=26&SubcatID=6
fatboyelroy 02-07-2013 07:26 PM
:thumbsup: Thanks for the tip on filling the gap. Is my approach to finishing off the entire surface sound?
joecaption 02-07-2013 07:29 PM
No, what you suggested will just crack, what ever goes there needs to be flexable.
fatboyelroy 02-07-2013 08:13 PM
Not the joint area but the entire sun deck surface. There used to be tile. I ripped it all up and want to apply a decorative water based concrete layer, about 3-4mm thick.
joecaption 02-07-2013 08:43 PM
There's at least 2 concrete guys on here from time to time I'll let them suggest something.
