#1 |
layout for multiple rooms
When transitioning from a bedroom to a hallway which will enter a living room. Should I lay all planks in the same direction or change at the doorway?
#2 | |
Master General ReEngineer
layout for multiple roomsQuote:
#3 |
Assuming your meaning flooring, install the same way. Just keep putting pieces into the hallway and work your way down the hall.
#4 |
Nail down flooring goes perpendicular to the floor joists. If the subfloor is slat, it goes perpendicular to that. If it's diagonal, put it at least 45 degrees off the subfloor orientation.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
| Display Modes | |
| Lost power to two Rooms and Cannot Get it Back | Zinge | Electrical | 9 | 08-08-2011 10:13 PM |
| Ceramic tile layout in several adjoining rooms | Johnnie3fingers | Flooring | 1 | 07-27-2011 08:00 AM |
| Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? | cmgoss | HVAC | 1 | 06-29-2011 06:12 PM |
| Bathroom DWV Layout Problems | grymes56 | Plumbing | 8 | 05-15-2011 10:00 AM |
| Laminate wood floor layout questions | nathan.tran | Flooring | 4 | 08-30-2008 11:56 PM |
