Old 08-19-2011, 07:11 AM   #1
laying 60cm x 60cm glazed ceramic tile
i would like to know how many pieces of 60cm x 60cm glazed ceramic tile can be laid within 8hours? or....how many pieces of 60cm x 60cm tile could be laid in a concrete flooring, and how long would it take? just an average estimate..
macasusirex is offline   Reply With Quote
Old 08-19-2011, 07:21 AM   #2
Those are BIG tiles, are you looking for a casual estimate or for a pro??? What size room??? How many impediments(things to cut around), etc??? That sounds like a multi-person job.
Old 08-19-2011, 08:03 AM   #3
Super Moderator
All floors are not the same----A gym floor ---lots in a day.
a narrow hallway full of doors--not much---
Old 08-19-2011, 09:07 AM   #4
the floor area is not big but ill be using 60cm x 60cm ceramic tile, one bedroom has the dimension of 3.5m x 4.5m to be laid with this tile, the layout is plain rectangular, so does anybody know how long would it take to lay 60cm x 60cm tile?i mean, how many tiles per hour..?
i just wanted to know, the number of tiles that can be laid at a specific manhours..
Old 08-19-2011, 09:26 AM   #5
Super Moderator
So much depends on the skill of the installer--the tools used---distance to the work station.
With one helper I have set as much as 1300 square foot in two days--
other times as little as 100----why are you asking ?
Are you trying to see how long it will take you?
Or are you trying to see what it will cost to hire someone on an hourly basis?
Old 08-19-2011, 09:31 AM   #6
Super Moderator
I just calculated the tile size to inches---those are very large tiles almost 24x24 inches--
Add extra time to the instalation as the large tiles take more time to level and cut.
Old 08-19-2011, 09:56 AM   #7
my concern is the speed of this work, not about how much will it cost..
if you can lay 1300sqft. in two days, that means you can lay 325pcs (or less) of 24in.x24in. tile in two days with one helper.?
or, that would also mean you could lay 162 pcs.(or less) of 24in x24in in one day, approximately 8hours, right?
Old 08-19-2011, 10:07 AM   #8
Super Moderator
That was a wide open area with only three doors.
Typical production in a day with one helper and plenty of cuts might be closer to 300 to 350 square foot .
macasusirex (08-19-2011)
Old 08-19-2011, 10:13 AM   #9
that one helps! thank you so much, so it's more or less 70pcs in a single day.. alright..thanks for the replies.. thank you so much...
Tags
tiling
Putting wall ceramic tile over wall ceramic tile in bathroom shower Dottie43 Kitchen & Bath Remodeling 1 07-14-2011 12:38 PM
Water Damaged Ceramic Tile DoubleTrouble Flooring 4 06-12-2010 03:17 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
