Launching Ramp In Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 10:56 AM   #1
Launching ramp in water
Ineed to build a launching ramp into a dam. I have no experience with this. I have a lot of building experience.
How do i install a foundation in water?
How do i cast concreate in water?
Can i use precast lintols like econoslab for a ramp?
Any advice would be apreciated!
Charles geyser is offline   Reply With Quote
Old 02-12-2012, 03:11 PM   #2
DIY staff
Rewards Points: 7,174
More info needed--a picture of the dam and the pond would help
Charles geyser (02-13-2012)
Old 02-12-2012, 05:19 PM   #3
"By the middle of the 1st century, the principles of underwater construction in concrete were well known to Roman builders. The City of Caesarea was the earliest known example to have made use of underwater Roman concrete technology on such a large scale.[2]"
The Following User Says Thank You to Yoyizit For This Useful Post:
amakarevic (02-13-2012)
Old 02-12-2012, 07:31 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I see people sandbag off the area and I've seen people build forms on a barge, lower them into the water, then fill them full of concrete, which forces the water out.
And the concrete still sets up.
I live on a huge lake, so I've seen everything from boat ramps and docks to heliports built on (in) the water.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Old 02-13-2012, 04:07 AM   #5
Hi, thanks for the reply. Would like to post a picture but still dont know how. My first round on this site. Will send picture as soon as i understand how.
Old 02-13-2012, 04:09 AM   #6
Thanks. Do they build these forms from steel?
Old 02-13-2012, 07:43 AM   #7
Disabled wood vet
titanoman's Avatar
I've seen wood and metal used for forms.
Old 02-13-2012, 12:44 PM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
How to attach a photo to a post
Old 02-13-2012, 04:12 PM   #9
I think you want 'hydraulic concrete' or 'hydraulic cement' in large quantities but I can't readily find a supplier on the Net.
You should probably sink rods into the bottom soil to adequately anchor the ramp.
Old 02-16-2012, 12:22 AM   #10
Registered User
Rewards Points: 4,912
Regular-mix concrete works fine, strong enough PSI to drive on....... Mix it slightly dry, dump it in, it stays together. Waves are hard on any finish though.
Gary
Old 02-18-2012, 02:03 PM   #11
When we redid our boat ramp they poured it in the shore and then pushed it into the water.
UFoPilot is offline   Reply With Quote
Old 02-18-2012, 02:58 PM   #12
Disabled wood vet
titanoman's Avatar
Gary
Explains why those ramps are so rough on bare feet.
Charles geyser (02-19-2012)
Old 02-18-2012, 03:58 PM   #13
Rewards Points: 12,830
We have to do the same thing around here as UFOpilot stated.
They make us pore on the shore and roll them in place.
Last one I did where were lucky and had an escavator on site for some other work so we made up some rebar U bolts to hook the chains to, to lift it to put 3" PVC under it to act as rollers and pull it into place.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
