Lathe To Fix A Large Gap In A Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 07:45 PM   #1
Lathe to fix a large gap in a block wall
After cutting in new plumbing into my block wall, I've got a good size gap (several inches square) left from my over zealous cutting of the block. Can I just put some lathe over it with stucco since it's going to be behind drywall?
WoodmanFL is offline   Reply With Quote
Old 12-11-2011, 07:52 PM   #2
Rewards Points: 14,306
Lets see, hmm, no picture no idea.
Where is the patch needed?
Old 12-11-2011, 08:07 PM   #3
I should have loaded the photo originally. Sorry. This will be behind drywall once completed.
Old 12-13-2011, 01:02 PM   #4
Any takers on my question?
Old 12-13-2011, 01:33 PM   #5
Reg PVC outside. Hmmm I think you made a mess. I would say fill in with mix but it might crack the piping when it drys. Or crack do to low temps. Hmmmmm
WeAreHandy is offline   Reply With Quote
Old 12-13-2011, 01:49 PM   #6
This is all inside a home in FL. No freezing here.
Old 12-13-2011, 01:54 PM   #7
I don't know if its available where you live. but I would just buy some of that spray foam insulation that wont shrink or expand from tempeture and fill behind the pipes try not to get too much in front in case you ever get a leak and have to fix the pipes.
Since its behind drywall it will keep the pipe from moving and act as insulation from the concrete blocks.
Just a thought hope it helps.
Fsitlts is offline   Reply With Quote
Old 12-13-2011, 01:56 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just cover it up with drywall it doesn't require filling.
In fact if that is an outside wall I think I would leave an opening there anyway just so as to benefit from the warmth of the inside of the house.
Old 12-13-2011, 05:47 PM   #9
retired union carpenter
Send a message via Yahoo to coupe
I agree with Bud. just leave it as is. but, leave an access panel in case of leaks.
as always, just my thoughts.
good luck
coupe
coupe is offline   Reply With Quote
Old 12-13-2011, 06:12 PM   #10
joed's Avatar
Rewards Points: 13,718
Exactly what I was thinking. It is going to be covered with drywall. Just leave it. How would you fit one these in there anyway.
Old 12-13-2011, 06:48 PM   #11
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
And please...for the love of gad man, take away the pictures.
Mine eyes are greatly offended.
Andy.
AndyGump is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
secure a wall frame to cinder block oddjobrookie Carpentry 12 12-05-2011 03:54 AM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 11:19 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Installaton of Exterior French Door in 8" Block Wall kgt55 Building & Construction 6 06-20-2009 09:59 AM
