Lath - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 02:49 PM   #1
Lath
I want to remove the plaster and lath on my 1912 house, so I can install insulation and drywall. When I remove the lath will I lose any lateral racking strength?
jvc120er is offline   Reply With Quote
Old 07-22-2008, 03:26 PM   #2
no it is up just to hold the first coat of plaster
clasact is offline   Reply With Quote
Old 07-22-2008, 03:53 PM   #3
Yes I know, however, if there is no other lateral bracing would it even help a little?
Old 07-22-2008, 03:58 PM   #4
are you telling me their is nothing behind your lath.It cant have been nailed to just the studs and plastered on top.Whats behind it??????
Old 07-22-2008, 04:00 PM   #5
Drywall contractor
Rewards Points: 1,070
The new drywall will serve the same purpose.
bjbatlanta is offline   Reply With Quote
Old 07-22-2008, 04:21 PM   #6
Registered User
Termite's Avatar
The lath might add a little rigidity to the walls and floor/ceiling framing, but it is insignificant. The proper installation and fastening of sheetrock will easily accomplish the same thing. I can tell you that the lath is not considered a structural element of the house.
Old 07-22-2008, 04:52 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In the majority of such remodeling projects (where you have old style plaster and lathing), the best approach to updating the walls is to: Remove the lathing and old plaster, Then, install re-usable lathing, or purchase new lathing, vertically over the existing studs.
When you install your sheetrock (often using 52" Wide sheetrock)....The added lathing strips brings the finished wall surfaces back out to match the existing window and door casings widths (unless all of those are being replaced).
- Build Well -
Installing baseboards on lath & plaster B Scott Remodeling 6 07-05-2008 09:29 PM
Interesting dilema - need advice CowboyAndy Electrical 12 03-13-2008 11:58 AM
Finding studs in a lath and plaster wall Oilerz Remodeling 8 03-02-2008 11:52 PM
Fishing through plaster and lath walls?? slatergrl Electrical 7 02-05-2008 08:29 AM
properly nailing down 1/2" osb sheeting over lath FISH275 Roofing/Siding 2 04-08-2007 12:49 PM
