Last Joist Hanger On Overhang - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 10:20 PM   #1
gkaro's Avatar
Last Joist Hanger on overhang
Hi all,
building an extension with a flat roof. 10" joists off a ledger board bolted to house for the roof. Question is about the outer 2 joists. How do you use a typical joist hanger if the joist is flush with the end of the ledger? Do you bend the outer hanger flat with the outside of the ledger and fasten sieways?
thanks
G
gkaro is offline   Reply With Quote
Old 04-04-2012, 10:31 PM   #2
Framing Contractor
Originally Posted by gkaro
Hi all,
thanks
G
Simpson sells right and left hangers for them.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-04-2012, 10:34 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
How about this?
sublime2 is offline   Reply With Quote
Old 04-04-2012, 10:36 PM   #4
Framing Contractor
Originally Posted by sublime2
How about this?
That will work.
Joe Carola
Old 04-04-2012, 10:37 PM   #5
gkaro's Avatar
have not seen anything like this at lowes or depot...
specialty?
Old 04-04-2012, 10:38 PM   #6
Framing Contractor
specialty?
You have to go to a real lumberyard.
Joe Carola
Old 04-04-2012, 11:56 PM   #7
Registered User
Rewards Points: 526
Here's the model number for the concealed-flange hangers: http://www.strongtie.com/products/co...U-U-HU-HUC.asp
Never used a right and left hanger as mentioned....
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
AndyGump (04-05-2012), sublime2 (04-05-2012)
Joist Hanger Size Question jjandshanon Building & Construction 8 02-05-2012 09:55 PM
Placing joist hanger on top of ledger instead of hangers. hnd83 Landscaping & Lawn Care 1 04-15-2011 08:32 AM
Joist doesn't match dimension of joist hanger! Stan Shmenge Building & Construction 9 03-15-2011 07:35 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
