Old 12-27-2007, 07:20 PM   #1
which laser should i get ?
i am primarily interested in being able to project right angles on concrete and other surfaces. i would guess something fairly basic.
Old 12-27-2007, 09:12 PM   #2
ICF Construction
Lasers comes with so many different vairables, it's visible in the price, you can buy a laser for $ 30.00 at HD and fight with it, or pay a few thousand and the thing self levels and everything. What are your applications and frequency of use?
Chris
Chris Johnson is offline   Reply With Quote
Old 12-27-2007, 09:17 PM   #3
i am probably looking to spend cca. $100 +/-, nothing too fancy. i like to be able to project right angles against a wall without using a drywall ruler or measure the same distance on the other side, also for framing which i am about to start once concrete is done etc.
i am just your average DIY-er who loves tools and does not mind staying hungry but buying the right tool.
thanks !
- a
Old 12-27-2007, 09:38 PM   #4
ICF Construction
$ 100.00 unfortunately gets something you will be most likely fighting with and has no tolerances for being 'off'. Most good ones shut down if it gets knocked or is not precisely level. I'd recommend looking on e-bay or such and see what's available, but, expect to be around $ 200 and up for something decent
Chris
Old 12-28-2007, 07:31 AM   #5
I have gas!
Clutchcargo's Avatar
I've been looking at the Pacific Laser Sytems PLS180. The best price I found online is about $279. Does anyone have any experience with this one?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-28-2007, 12:41 PM   #6
http://www.toolup.com/productinfo.as...%20PLS180-TOOL
Old 12-28-2007, 03:30 PM   #7
I worked for a steel stud and drywall company for a couple of years and we used pls lasers. Not the one shown, we had one with five beams(down, up, left, right, and forward) and they worked good. They stood up to the abuse of everyday use and worked great for framing up walls.
ponch37300 is offline   Reply With Quote
Johnson Rotary Laser Clutchcargo Tools 1 12-09-2007 04:18 PM
Laser level bubble dried up. ramakristan Tools 3 10-13-2007 08:38 AM
Shopping for a laser level - opinions appreciated. Kevin K Tools 8 05-08-2007 06:43 PM
Laser Levels laserlady Carpentry 10 12-14-2006 02:40 PM
Laser tools forcheck Tools 6 11-14-2006 03:24 PM
