Larson Storm Door Won't Close - Building & Construction - DIY Chatroom Home Improvement Forum
Closed Thread
Old 08-12-2009, 09:47 AM   #1
Larson Storm Door won't close
I just had an addition built with a new exterior door, the contractor is gone and the storm door has never closed. The handle strikes the exterior door jam, the knob for the deadbolt is so close to the door frame you can hardly turn it. and the dead bolt doesn't line up. I understand how to correct the dead bolt issue and strike plate, however how do you recess the doors hinge side to make it allow enough clearance for the handle to not strike the opposite door frame. I am ready to disassemble and start over. I have printed out the installation instructions and am ready to start, however I did not see any reference in trouble shooting regarding this problem.
Thanks,
Truly Annoyed
annoyed is offline
Old 08-12-2009, 09:49 AM   #2
Registered User
Termite's Avatar
I'd remove the door and start over. If you can remove the entire door and frame as an assembly just install some thin shims at the jamb side between the door and the jamb to guarantee clearance and re-attach it.
I installed one of those once and vowed that I'd never do it again.
Termite is offline
Old 08-12-2009, 09:55 AM   #3
Thanks for the reply but wouldn't shims make the matter worse. It appears that I need the frame to be further away from handle
annoyed is offline
Old 08-12-2009, 10:33 AM   #4
Registered User
Termite's Avatar
No, TEMPORARY shims between the door and the door's frame. They'll separate the door and the frame a bit during attachment.
Termite is offline
Old 03-22-2010, 02:50 PM   #5
Larson storm doors are known for their low cost and below standard cheap design & lack of durability. Do not by one. The main mechanical part of the door, the hinges, are made from aluminum, they can spring if opened too wide or if the wind catches it. The door will be rendered useless from that point forward, being unable to be closed. I have replaced dozens of larsons with virtually any brand other than larson. Do not buy them! Their designs are substandard and are not durable and their customer support has no commitment to quality either
kimherrick1 is offline
Old 03-22-2010, 04:48 PM   #6
waterman1971's Avatar
Rewards Points: 150
Double up your door facings on the outside.
Most storm doors are aluminum. What kind of material are yours made from?
waterman1971 is offline
Old 03-23-2010, 05:34 PM   #7
firehawkmph's Avatar
Rewards Points: 1,822
If the door flies open past 90 degrees when the wind catches it, then somebody didn't put on the safety chain. I have hung a lot of storm doors, both cheap ones and the fancy ones. When it comes to a price point, I didn't see one manufacturer being worse than the others. A cheap door is a cheap door. If installed correctly, however, they should provide reasonable service.
I find it strange that somebody's first post is to jump in and bad mouth a product instead of working on a solution. Not too good etiquette.
Annoyed,
It sounds like your contractor didn't do such a good install. Take the hinge side loose and see if you have room to move the door over some to get your clearance on the other side. Most new exterior doors that come with brickmold are sized to drop a storm door right into. Picture would help.
Mike Hawkins
firehawkmph is offline
Old 03-23-2010, 06:45 PM   #8
kwikfishron's Avatar
Rewards Points: 170
I’ve put in plenty of Larson’s and never had a issue with hardware clashing. Is the entry door swing in or out? If it’s a out swing them maybe I could see a problem. If the storm door frame is hung on the door trim that the siding buts into (as it should be) then I don’t see how hardware could interfere with each other, unless you have a out swing door then maybe. A picture would help.
kwikfishron is online now
Old 03-23-2010, 07:01 PM   #9
Original poster hasn't been back to the site in ~9 months
This was bumped by a One post wonder (kimherrick) who made the post & then left
I had 2 Larson doors at my last house & both worked great
Scuba_Dave is offline
Closed Thread
Larson Storm Door Hinges af3683 General DIY Discussions 3 09-23-2009 12:42 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-22-2008 12:37 AM
noisy storm door von Carpentry 1 08-10-2008 07:20 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
