Larger Opening On Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2007, 02:36 AM   #1
Larger opening on load bearing wall
I hope you guys can help me out.
I have attached a document (html) that shows my house dimensions and load walls
On the third diagram, the yellow highlighted area shows were I want to open the existing 32" opening to 96". Currently the header over the 32" doorway is (2) 2"x6".
I have done some investigation and calculations and of the opinon that (2) 1 3/4"x 11 7/8" LVL beams should more than support this span. I am asking for some opinons on that.
Also, below the first floor, under the load bearng wall in question, there are three 1 1/2"x 9" joists within an 18" span so I again belive I have the strength there to supprt the load each end of the 96" header.
I look forward to your responses.
Thanks...Greg
DamnRenos is offline   Reply With Quote
Old 08-03-2007, 11:36 AM   #2
Custom Cabinet Maker
Greg: IMHO I don't see an issue. In truth I even wonder if the wall in question is even load bearing. Normally with a construction like you have with a center steel I beam, normally the loads are from center to outside walls. If that wall is running parallel to the joists, which in your print it appears to be, it is not "bearing".
JackM
skymaster is offline   Reply With Quote
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
