10-02-2008, 03:57 AM
#1
Larger hole in foundation
I need to increase the size of a hole in my foundation that is aprox 1.25 inch now to something closer to 2 inches. I have never dealt with a hole this large before. Can I get a bit this large for my hiltie and drill out the hole larger?
I've drilled many holes through 8 top 12 inches of concrete with the hilte, but never any larger than about 5/8, maybe 3/4. Also I have not had to make an existing hole larger before.
Any suggestions on the best way to get this done?
Jamie
10-02-2008, 07:49 AM
#2
gravity always wins
If your Hilte will handle it, go for the 2" bit. That's going to be an expensive bit. Most likely a core bit, so you'll need an adapter too. Once you get the tooling, either cold chisel a recess to trap the bit so it doesn't wander or make a template to attach to the wall to trap the bit until you get partway into the hole.
10-02-2008, 11:01 AM
#3
drill a 'series' of small holes where you want the hole,,,or where it CAN work for you,,and take a chisel and connect them. You can drill many small holes with same effort as a big hole,,,maybe not QUITE as pretty. IF pretty matters,buy the expensive bit!!
10-02-2008, 11:21 AM
#4
the Musigician
orrrr, maybe just drill/chisel the hole big enough to allow you to easily work, then fill in with cement when done? but what do i know? i'm just a mouse.....
DM
10-02-2008, 12:02 PM
#5
I need to expand the current 1" hole, so I am not sure how I can manage the small holes around the 1" hole without slipping into the current hole with the bit. I have a chisel for the hammer drill, but never found it to work all that well.
Jamie
10-02-2008, 12:04 PM
#6
If I made a template and used the large bit, do you think this work work to expand the current 1" hole? i.e. if I center the template with a 2 inch hole on it over the current 1" hole, then drill with the 2 inch bit? I am just kind of unsure how it's going to work trying to expand the current hole to a larger one.
Jamie
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
