Large Window Close To Corner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 06:27 PM   #1
large window close to corner
Hi,
I need a bit of advice. I'm building a cottage and I want to put a 3' wide by 5' 9" tall window close to a corner. How close can I put it to the corner before I am creating a problem where I need to worry about lost shear control etc.
Sorry. this is single story, 2"x6" stick framed gable ended structure.
Thanks a ton...or tonne.
morpho is offline   Reply With Quote
Old 07-29-2010, 06:51 PM   #2
here is a "picture" of what I want to do. I would like to have it a bit closer than it appears here. It's currently 2'. I'd like it about a a foot from the corner.
Possible?
Old 07-29-2010, 07:47 PM   #3
the Musigician
DangerMouse's Avatar
I see no problem at 12". I installed 2 in a bedroom corner with 6x6 support and they ended up just about 12" from the corner on the outside, 6" on the inside. The inspector already saw it.... no problems.
Hope this helps.
DM
Old 07-29-2010, 07:50 PM   #4
Where are you located ?
Old 07-29-2010, 08:48 PM   #5
Registered User
Rewards Points: 4,924
Just put it there in the plans being reviewed by the Building Department. They will just require a shear panel (next to window on main house side) attached with a header to the corner and possibly some straps at the header and plate lines. A few hold-downs through the bottom plate to the concrete foundation or slab on grade and you're good to go.
Be safe, Gary
Old 07-29-2010, 09:54 PM   #6
WOW!
That was pretty fast!
DangerMouse, That is some serious green outside those windows!
Scuba_Dave, I am in Central Alberta Canada.
GBR, I fear the ideas the code guy's keep coming up with.
But maybe thats the thing to do. I was thinking of bracing with 2x4's between the 2x6 studs in a kind of lightning or zigzag pattern.
Old 07-30-2010, 09:46 PM   #7
Registered User
I was giving you my requirements for my seismic zone. Yours is right up there, too: http://earthquakescanada.nrcan.gc.ca...estcan-eng.php This is MINIMUM for shear flow at the corner for high winds or seismic activity. If no permit, and plywood sheathing or siding as in the picture, it's entirely up to you. (Don't hide under that corner in a big one.....) Years ago with board sheathing, code required let-in diagonal bracing at all corners. Research that if going that way as a lot of things factor in.... wall length, height, brace angle, bottom plate hold-downs, etc. Your B.D. has the info.
Be safe, Gary
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 09:23 PM
Window won't close completely bucksone General DIY Discussions 3 06-25-2009 06:57 AM
Close off a basement window mwerner General DIY Discussions 2 10-20-2008 08:24 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
