Large Section Of Siding Removed - Use House Wrap Before Re-siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 08:55 AM   #1
Large section of siding removed - use house wrap before re-siding?
Hi there,
I recently removed a large screened-in back porch. What I've got now is 2/3 of the back of the house that I need to install siding on.
Before I install the siding, it makes sense to put a water barrier on, such as a house wrap. However, this is not "new construction," so the windows and doors are already in place, etc.
Is there a certain technique to follow when installing the water barrier on old construction? Most of what turns up in searches is not applicable to my situation.
Thanks!
nelsonC is offline   Reply With Quote
Old 06-06-2011, 06:21 PM   #2
Rewards Points: 4,806
of course you're adding house wrap,,, the technique is tucking the new under the old siding & using const adhesive to seal the jnts,,, tools needed incl putty knife, utility knife, caulking gun, caulk, & beer
Old 06-06-2011, 07:43 PM   #3
Registered User
Rewards Points: 526
http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
http://www.greenbuildingadvisor.com/...stive-barriers
Gary
Old 06-07-2011, 08:06 AM   #4
thanks y'all!
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-16-2011 11:59 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Repainting large section of textured ceiling? ChrisT Painting 2 02-12-2008 12:54 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
